Electrical Q's: Ground(s)
Old Jul 21, 2016 | 07:09 PM
jhl3's Avatar
jhl3
Besides the body to chassis/frame ground on the passenger side of the truck near the back of the leaf spring, is/are there a/any additional body to chassis/frame ground(s)?
Is there any reason to limit the gauge of wire, as in larger, when replacing the OEM multi-stranded non-insulated copper strap? Why was this type chosen originally by the electrical engineers?
Should I simply bite the bullet and purchase the OEM strap? Or, could I simply use some 4 or 6 gauge wire?
The one on this truck is tired, brittle and blue....
Old Jul 21, 2016 | 08:02 PM
F350-6's Avatar
F350-6
No reason not to use regular ground wires, or even add additional grounds of your own.
I added a 4 ga. ground cable from my driver side battery to one of the mounting bolts on my alternator. Additional or replacement grounds are easy to add.
Old Jul 21, 2016 | 08:06 PM
jhl3's Avatar
jhl3
I knew I had copied that from someone on here, I just could not remember who. Thank you.
Old Jul 21, 2016 | 08:07 PM
Pikachu's Avatar
Pikachu
There's also a ground strap from the back of the right head to the body.
Old Jul 21, 2016 | 08:19 PM
jhl3's Avatar
jhl3
I have seen it on our '02 but not on this e99. Maybe it was removed by the PO. I do have one on the negative terminal wire on the DS battery to the body though.
Old Jul 21, 2016 | 08:25 PM
pirschwagon's Avatar
pirschwagon
The main "chassis ground" is one (1) AWG Smaller than the primary Battery (+). A 4-AWG as descried is sufficient.
As F350-6 has mentioned. Consider grounding your Alternator Case to the (-) Battery Post as well with the same size wire. The mount and bolts are less than desirable as they corrode. I was reading an article in a trade magazine that, at least "in theory", this will help reduce heat on the internal rectifier and regulator.
In addition to what Pikachu pointed out, make sure the Bed is strapped as well. And, I can't recall where that one is. Perhaps not. Its been eons since I removed a Bed.
Old Jul 21, 2016 | 08:33 PM
Pikachu's Avatar
Pikachu
All the 7.3 Powerstroke equipped trucks should have it, including the OBS trucks. It isn't much fun getting bolted to the head if you forget to attach it before dropping an engine in, either.
Old Jul 21, 2016 | 09:07 PM
jhl3's Avatar
jhl3
Thank you for the clarification. I am not doubting you at all. The PO did some head scratching stuff to this truck. There are wires that I have no idea where they went or what they were for. I get confused at times...I am trying to remove them one at a time. They are not OEM.. I will look again and get back to you.
Old Jul 22, 2016 | 07:38 AM
Tugly's Avatar
Tugly
The two very important grounds I have worked with go directly to the block. There is a ground lug on the driver-side of the block that goes directly to the negative post on the driver-side battery, and the same arrangement exists on the passenger side. I do not recommend grounds from the batteries to the chassis - I recommend they go straight to the block, then you can ground the chassis to the block. Here's why:
There is absolutely nothing on the chassis that uses the Cold Cranking Amps available from the batteries, unless you add something big - like a hydraulic pump for a plow. The starter motor and the glow plugs use all the juice - and you want the fewest possible "jumpers" between the batteries and the block. Given that, I went so far as to read the ohms between each battery ground post and the block - this is when I found a poor connection on the driver-side ground. I removed the ground cable, cleaned the holy hell out of all connection points, and re-installed. The ohms then dropped to zero after my work.
Old Jul 22, 2016 | 05:34 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Good tip, Rich!
Old Jul 22, 2016 | 06:06 PM
timmyboy76's Avatar
timmyboy76
Bed grd to chassis is in front of p/s rear wheel....edit, nevermind. Found one under p/s door
Old Jul 25, 2016 | 02:50 PM
jhl3's Avatar
jhl3
You sir, are correct. No surprise there!
On this truck it is a much smaller braided non-insulated strap that goes from the PS head over top of the HVAC fan/blower compartment and bolts to the cab portion of the truck. I will be cleaning it later tonight. It too is blue...
Thank you for the tip.
Old Jul 25, 2016 | 02:54 PM
jhl3's Avatar
jhl3
Originally Posted by Tugly
......... - and you want the fewest possible "jumpers" between the batteries and the block.
I am curious as to why? Some circuitry will use a jumper to ground for each component......
Old Jul 25, 2016 | 10:05 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I interpreted Tugly's meaning differently. I think he was trying to convey the idea of wanting the least amount of resistance in the ground path... meaning as few point to point connections in series between the battery and the block.
In other words, if given a choice between two ground circuits...
A. Cable from battery directly to block
or
B. Cable from battery to body, then another ("jumper") cable from body to block
... then the preferred embodiment of a ground circuit would be A, as it contains fewer "jumpers", or connections, or points of resistance, or points of contact failure.
What you are talking about is direct and separate grounds for each component in a given set of circuitry... which essentially is exactly what I interpret Tugly to be talking about. Essentially, your anecdote illustrates the same direct connection to ground circuitry that Tugly is trying to convey. You guys are on the same page, as I see it.
Old Jul 26, 2016 | 07:52 AM
Tugly's Avatar
Tugly
Yup - grounds in parallel or a "home run" connection (connected to a central point) are best. Y2KW57 got it.
