Electrical Q's: Ground(s)
Old Jul 26, 2016 | 03:37 PM
jhl3's Avatar
jhl3
Originally Posted by Y2KW57
I interpreted Tugly's meaning differently. I think he was trying to convey the idea of wanting the least amount of resistance in the ground path... meaning as few point to point connections in series between the battery and the block.
In other words, if given a choice between two ground circuits...
A. Cable from battery directly to block
or
B. Cable from battery to body, then another ("jumper") cable from body to block
... then the preferred embodiment of a ground circuit would be A, as it contains fewer "jumpers", or connections, or points of resistance, or points of contact failure.
What you are talking about is direct and separate grounds for each component in a given set of circuitry... which essentially is exactly what I interpret Tugly to be talking about. Essentially, your anecdote illustrates the same direct connection to ground circuitry that Tugly is trying to convey. You guys are on the same page, as I see it.
Thank you for the detailed clarification/confirmation. Sometimes I need big pictures that are drawn with Crayons....
Originally Posted by Tugly
Yup - grounds in parallel or a "home run" connection (connected to a central point) are best. Y2KW57 got it.
Thank you for the more detailed clarification.
JayBourbon
Dec 29, 2017 10:23 AM
PRIMERED79 SHORT BED
Aug 14, 2016 10:12 PM
bikeymikey
13
Mar 24, 2013 09:00 PM
Eric H
Sep 26, 2009 06:10 PM
n9lhm
Dec 17, 2005 11:17 AM
