wont start
Old Jan 15, 2002 | 07:22 AM
chulsey12's Avatar
chulsey12
wont start
90 bronco 351 , started it this morning and after about 5 seconds of running ok, it just died, then i tried to start it again and it just sits there and turns over, havent pulled check engine codes yet,, any ideas?
Old Jan 15, 2002 | 08:37 AM
PAUL_2's Avatar
PAUL_2
wont start
Check for fuel & correct fuel psi & spark .
Old Jan 15, 2002 | 09:19 AM
kellyb's Avatar
kellyb
wont start
can you still hear your fuel pump turn on ? on my '90-5.8 i can hear my pump come on after i turn the key on. check the fusible link wires near your battery also . make sure not are melted.
Old Jan 15, 2002 | 05:55 PM
Norten's Avatar
Norten
wont start
I had a similar problem with my '87 F-150 300 a few weeks ago. Started fine one day, nothing the next. Got spark, fuel pump was pumping. Turned out, after trying a lot of other stuff, to be a broken wire at the fuel pump relay.
Norten
Old Jan 16, 2002 | 02:57 AM
Rockstar's Avatar
Rockstar
wont start
Sounds like the ignition modual on the distribiture...cant spell worth a shi#.\
Old Jan 16, 2002 | 06:32 PM
chulsey12's Avatar
chulsey12
wont start
is the ignition module and the coil the same thing
Old Jan 16, 2002 | 09:17 PM
kellyb's Avatar
kellyb
wont start
no, the ignition module is on side of distrib. w/ wires plugged into it. the coil is the thing the center spark plug wire (on distrib.) plugs into. the ignition module can be removed without removing the dist. if you get the special tool from auto parts store. (less than 10.00) you should check codes first.
Old Jan 16, 2002 | 10:45 PM
Pastmaster's Avatar
Pastmaster
wont start
Jeff Watts
Jul 13, 2013 09:42 PM
ssnbdr75
Oct 13, 2011 06:33 AM
mauro12
Jul 21, 2011 09:17 PM
Dkanngiesser
Electrical Systems/Wiring
Dec 13, 2007 07:54 PM
Just Strokin
Jan 23, 2002 10:48 AM
