Instrument/dash lights
Old 07-21-2016, 09:59 AM
JJD's Avatar
JJD
JJD is offline
I have a 2001 f250. Has anyone replaced the lights in your dash I have a few going out on mine and just wondering how big a deal it is to replace
Old 07-21-2016, 10:28 AM
derek0525's Avatar
derek0525
derek0525 is offline
Are you talking about the guage bezel. Or where your heater switches and stuff are. If it's the guage panel it's pretty easy.
Old 07-21-2016, 10:41 AM
JJD's Avatar
JJD
JJD is offline
The gauge bezel. My left side is getting pretty dim
Old 07-21-2016, 06:05 PM
268Fords's Avatar
268Fords
268Fords is offline
I recently replaced all of mine with led's. I would suggest to not replace the high beam indicator with an LED. Way to bright. Also don't replace the air bag light with an LED due to it staying dimly lit.
Old 07-21-2016, 07:28 PM
JJD's Avatar
JJD
JJD is offline
Is there any how to instructions anywhere? Where did you get the LED's at? In definitely need some illumination.
Old 07-21-2016, 08:48 PM
pirschwagon's Avatar
pirschwagon
pirschwagon is offline
The Gentlemen in this video is a member here. I have used his guidance with great success over the years. In this video he explains the how-to in removing the cluster.
Old 07-22-2016, 01:47 AM
268Fords's Avatar
268Fords
268Fords is offline
I ordered bulbs from superbrightleds. Dash illumination bulbs are #74-GHP3 green (6 of them), turn signal #B8.5D-GHP green (2 of them), temp control and fan #B8.5D-WHP white (2 of them). You have to slightly bend the electrical contacts upwards for them to work. They are also polarity sensitive, so just plug the instrument cluster in and turn the lights in before reinstalling. I almost want to put regular bulbs back in for the turn signals because they are so bright to. I used white for the temp/ lean control since the temp dial has white and red. They ended up working perfectly for lighting up the green sections. But like I said, stay away from the blue led bulb for the high beam because it's too damn bright. All the bulbs dim with the dimmer switch like incadescents.
043506.06speed
1983 - 2012 Ranger & B-Series
08-19-2011 12:23 PM
superduty2001
1999 to 2016 Super Duty
03-21-2011 04:57 PM
bbri4570
02-02-2008 06:40 PM
Heff2727
Electrical Systems/Wiring
09-13-2004 09:09 PM
Traderjoe28
09-03-2003 12:52 PM
Quick Reply: Instrument/dash lights
