Aerostar Ford Aerostar
Servicing Front Axle
Old Aug 18, 2003 | 05:57 PM
TimC's Avatar
TimC
Question Servicing Front Axle
Hi folks, newbie here with a question about front axle service on a '96 Aerostar 4x4 van. I'm trying to help out a neighbor who can't find where to check the level, or add lube to the differential and the two hubs. He doesn't have a repair manual, and his owners manual says the lube has to be changed at both these places. Thanks for any help, Tim
Old Aug 19, 2003 | 09:44 PM
tbpbft's Avatar
tbpbft
There is a Hex plug on the right (passenger) side of the diff, above the front driveshaft. It takes a 3/8 inch allen wrench to remove it. Once it has been removed, stick your finger in it, the fluid level should be at the bottom of the hole. The front diff takes Automatic Tranny Fluid, NOT 80/90.
The front end uses CV joints, so the only place to check or add fluid is the differential.
Old Aug 20, 2003 | 12:03 AM
TimC's Avatar
TimC
Thanks for the help tbpbft, I'll pass it on to my friend.
bduemig
May 16, 2014 04:56 PM
BCO2JCO
Apr 9, 2007 09:55 PM
sportscar
Feb 5, 2006 10:08 AM
'06 Dually Boy
Jan 11, 2006 10:51 PM
john111222
Oil & Lubrication
Sep 5, 2004 06:17 AM
