92 zf5 on 91...will it work?
Old Jul 20, 2016 | 03:50 PM
jmuenchow's Avatar
jmuenchow
i have a zf5 out of a 1992 that i want to put into my 1991...will i be able to make it work since i have a cable driven speedo? my truck is 2wd.
if it will not work will i be able to get a cluster, sensor from a 92 and convert mine to a sensor driven speedo?
thanks in advance
Old Jul 20, 2016 | 04:20 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
The 92 ZF5 has no provisions for a speedometer cable, the hole is cast there, but not machined out nor is there any provisions on the tail shaft ... However, if you have eyes on the transmission verify if it has one or not, you could get lucky!
As for changing over to a 92 dash, I do not know, never tried!
Someone else may know.
-Enjoy
fh : )_~
Old Jul 20, 2016 | 05:33 PM
IDIoit's Avatar
IDIoit
the clusters may fit,
but if youre trying to use the whole dash....
https://www.ford-trucks.com/forums/1...-detailed.html
Old Jul 20, 2016 | 06:29 PM
wtroger's Avatar
wtroger
The 92 uses a oss or vss sensor for speedo. pretty tough to make that work in a 91 that had both cable and a oss sensor. I have a older Ford truck that the speedo doesn't work in. I use a cheap Gps to monitor my speed.
Old Jul 20, 2016 | 07:40 PM
jmuenchow's Avatar
jmuenchow
Ok thanks for all the info guys..I've also read that I could use an e brake mount off of an f450??? How exactly could this work?
Old Jul 20, 2016 | 07:41 PM
jmuenchow's Avatar
jmuenchow
I have tried to research the problem I'm having but most are 4x4 so the speedo is though the transfer case which sucks because I'm 2wd
Old Jul 20, 2016 | 07:50 PM
Festus Hagen
Methanoholic
The F450 uses a 4x4 ZF5, the E-Brake adapter attaches where a Transfer case would, adapting it to 2wd and giving the F450 a Driveline E-Brake.
It will not help solve your Speedometer issue in the 91 with a 92 Transmission.
A solution could be as simple as adding a transfer case and leaving it in high range, no front driveline ... Not a path I would go down though!
EDIT
You would be better off finding a 87-91 ZF or forget about the Speedometer, something I wouldn't do!
-Enjoy
fh : )_~
Old Jul 20, 2016 | 07:57 PM
jmuenchow's Avatar
jmuenchow
EDIT
You would be better off finding a 87-91 ZF or forget about the Speedometer, something I wouldn't do either!
-Enjoy
fh : )_~
I like the idea of a HUD GPS speedo. I just don't want anything bulky because I like a sleek dash look (old truck I know but it's my baby I take care of it)
Although I hate the fact of the speedo not working it will be weird in a way for me (hard to explain I know I sound silly)
And the odo not working although I know some GPS can track the odo.
Honestly I will probably go with the HUD GPS route if it is a good sleek design and can keep an odo.
I got the transmission for a REALLY good deal.. 155k miles in working condition for 100$.
Can anyone chime in on their experiences with the GPS speedo?
Thanks everyone!!!
Old Jul 20, 2016 | 08:05 PM
Festus Hagen
Methanoholic
It would drive me bonkers! (more than I already am)
I see why you are trying so hard, that's a decent price.
-Enjoy
fh : )_~
Old Jul 20, 2016 | 08:06 PM
jmuenchow's Avatar
jmuenchow
-Enjoy
fh : )_~
In all honesty I know I can sell the zf for at least my money I paid for it but then I would be put back to square 1 of looking for the correct zf
Old Jul 20, 2016 | 08:19 PM
Festus Hagen
Methanoholic
I'd double your money if we were close and it checked out to me ...
-Enjoy
fh : )_~
Old Jul 20, 2016 | 08:35 PM
wtroger's Avatar
wtroger
jmuenchow clear your messages. trying to send you a message.
Old Jul 20, 2016 | 10:45 PM
jmuenchow's Avatar
jmuenchow
Sorry about that just cleared them
Jzisakis
Sep 10, 2018 12:56 PM
Rodger49
15
Apr 13, 2014 08:56 PM
munsokahn
Oct 16, 2013 08:12 PM
Nick1911
32
Aug 23, 2008 10:01 PM
jpegg
1983 - 2012 Ranger & B-Series
Nov 15, 2004 06:06 PM
