Ball joints
Old Jul 19, 2016 | 03:20 PM
cappo's Avatar
cappo
Ball joints
Hi guys was wondering if I can find out how to check the ball joints on my van. I had heard to lift the wheels off the ground and lift each tire from underneath with a prybar? Or maybe a better method.
Thanks
1999 E-150
Base model 4.6
Old Jul 20, 2016 | 03:17 PM
blageurt's Avatar
blageurt
you lift the tires off the ground , then you grab the tire with hands at 12 and 6 o'clock and try to move the tire up and down to check if there is play....If it moves at all the Ball Joints are baked....It also helps to have someone looking at the joints themselves to verify that there is play...But ussually you can feel it...For the Tie rod ends you put your hands at 3 and 9 o'clock and check for play in a similar way...thats how I do it anyway....
Good Luck
Old Jul 20, 2016 | 04:41 PM
cappo's Avatar
cappo
Thanks I will give it a try
Old Jul 21, 2016 | 12:47 PM
vettex2's Avatar
vettex2
jack it up by the suspension, not the frame
Old Jul 21, 2016 | 02:56 PM
jimbomitch's Avatar
jimbomitch
I usually use a bar on the bottom of the tire when checking them. A little lever action.
Old Jul 21, 2016 | 08:14 PM
Im50fast's Avatar
Im50fast
This is what I've been thinking.
Ball joints must be checked unloaded, and depending on its position that would involve lifting by the suspension or by the frame.
Old Jul 22, 2016 | 01:56 AM
Toppa's Avatar
Toppa
before two months i replace the whole Chassis infront of my van. it wasnt possible to feel Play in the balljoints before, while i disassembled the Chassis i've seen most of the Joints where done... If ist possible to feel, your Joints were completely dead. the way i see it is heavy cars arent checkable by Hand or bar. Not reliable.
bigcountry1009
Jun 19, 2014 03:28 PM
scameron
Jul 4, 2011 08:23 PM
MOSPARKY
Aug 29, 2009 01:13 PM
arno
Feb 6, 2008 09:57 AM
Broncobigtire
1978 - 1996 Big Bronco
Mar 19, 2004 08:54 PM
