ball joint check
Old Aug 28, 2009 | 12:35 PM
MOSPARKY's Avatar
MOSPARKY
ball joint check
Sorry my wife had a garage sale that got rained out and my chilton is hopelessly buried somewhere under all that crap.
I have a 99 Expy auto 4wd with 80,xxx miles. The drivers side tire is wearing on the inside. I suspect the a ball joint may be bad. I've never even rubbed a tire hard, so until I can rule out the ball joints I'm ruling out the alignment.
How do I check the joints for excessive play ?
Old Aug 29, 2009 | 12:43 AM
aquanaut20's Avatar
aquanaut20
jack up front, place a lever under the tire and lift, get someone to watch the BJ as you apply the lift. A bad on will separate.
Old Aug 29, 2009 | 08:45 AM
steve(ill)'s Avatar
steve(ill)
jack up under the A frame so the tire hangs in the normal position. dont jack under the truck frame where the tire hangs real low and will bottom out the spring and put a load on the ball joint. i use a 4 ft 2 x 4 to stick under the tire and lift up and down 2-3 inches. look at the ball joint while doing that.
Old Aug 29, 2009 | 01:13 PM
MOSPARKY's Avatar
MOSPARKY
Thats what I thought. Thats howe I was taught years ago. I had tried that before I posted, but detected no play. That's a good thing, I think. At only 80,xxx miles, I would have been more than a little disappointed in Ford if I had to replace ball joints already. I guess it's time to have the alignment checked. The kid did use the truck a few times, hard to say what she may have done.
All other tires are wearing well, no shake in the wheel, tracks well if I let go of the wheel. I do sometimes feel a slight shift when I make a hard turn coming out of a parking lot. That could be the hubs trying to lock in due to the difference in axle speeds I guess.
Any other suggestion that I can check myself, before heading to the shop ?
