76 ford 302
Old Jul 22, 2016 | 06:31 AM
8086ford's Avatar
8086ford
76 ford 302
I got a 76 ford 302 it came out of a mustang 2.. I want to put it in a 78 f150. 4x4 since this is a car engine that I'm rebuilding can I redo everything inside as if it was a truck engine. And is the Pistons the same?? Thanks in advance
Old Jul 22, 2016 | 09:23 AM
Justin Jones's Avatar
Justin Jones
There are piston applications that will work for either car or truck. I would do some research to figure what compression I want to work with the heads I plan to use. I've read (I don't remember where) that the mid 70's 302 blocks had taller deck heights that will result in lower compression. You may also get a reputable machine shop to check the deck height and square deck if it is taller to be able to use a more common piston.
Old Jul 24, 2016 | 08:26 PM
baddad457's Avatar
baddad457
In 76, all the 302's in all application had the same "Grand Canyon-esque" dished pistons (bout 1/4" deep, if not deeper) in them. The comp ratio was 7.8 to 1. If you want to pep it up, shoot for as close to a 1.620" pin height flat tops, better yet, stick a 351 in there that'll run rings around any 302 with it's 1/2" longer stroke.
stormr
Sep 19, 2024 12:27 AM
kellar
18
Nov 9, 2007 07:40 PM
pud
Apr 18, 2007 02:05 PM
cooljman1
Oct 22, 2006 11:06 AM
Midnight Knight
Oct 20, 2002 10:51 AM
