Weird starting problem - 4.9L
Old Sep 30, 2003 | 11:26 PM
PhatCaprice's Avatar
PhatCaprice
Truck: 90' F-150
Engine: I6 4.9L w/ Man. Trans. Fuel injected.
The only way to get it to start is to feather the throttle back n' forth until it starts (I know fuel injection, but it won't start without moving the throttle some, maybe TPS sensor?) and even then, you have to rev it past like 1000 rpm to keep it running, then after like 30 seconds of that, you can let go of the gas and it will continue idling like a champ. And after that, if you rev it, it runs solid - so it doesn't appear to be anything mechanical. It does this hot or cold, so I ruled out the IAC sensor. Also fuel pressure checks out ok without leaks as well as spark. Maybe the TPS? I've seen that sensor do some crazy things on GM cars, but it's not throwing the check engine light after we get it started. Can I still scan it and get a code if the Check engine light ain't on? Thanks in advance.
Old Sep 30, 2003 | 11:28 PM
PhatCaprice
...oh yeah, checked for vacuum leaks, didn't find any.
Old Oct 1, 2003 | 09:17 PM
couleeman's Avatar
couleeman
I just bought a TPS from the local ford dealer for $30. If I recall right, it did not trigger any codes when the neighbor ran it on his little computer, but it didn't get any readings from it either.
Hope this helps, but for $30, I would just replace it and try it. Can't hurt.
Old Oct 2, 2003 | 08:00 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
I would put my money on a bad TPS. Yours probably has dead spots in in and whenever you feather the throttle you revive it long enough for the computer to see it and start the truck. A good way to test it is to put a voltmeter on its connector. You should see a nice linear transition the more you open the throttle plates. Full open reads about 4.6 volts. BTW I like your avatar, that little character is hilarious on TV.
Old Oct 2, 2003 | 12:53 PM
PhatCaprice
Update... I replaced the EVR (EGR?) solenoid controller (a white thing with a plunger), and in starts flawlessly now! Thanks for all the suggestions guys.
Special Ed rocks!
Old Oct 12, 2003 | 08:27 PM
Rollyfingers's Avatar
Rollyfingers
Hey, PhatCaprice, my truck is doing the exact same thing. You mentioned you replaced the EVR or EGR solenoid controller. Would you be referring to the EGR Valve? If not, could you be more specific as to what the part was.
Old Oct 13, 2003 | 09:15 AM
95se5m's Avatar
95se5m
Same here, I was thinking IAC or TPS. What exactly did you replace? I am having the exact same problem, I would love to get it fixed without lobbing parts at it till it's fixed.
Old Jan 12, 2004 | 08:02 PM
fallguy's Avatar
fallguy
TTT
Any word on what the fix was?? I'm having same issue. Starts fine cold, but when it's warmed up a bit it turns over 5 seconds before it will start.
Old Jan 13, 2004 | 02:42 AM
bigbadjs's Avatar
bigbadjs
He's talking about the EVP sensor .
Its attached to the egr valve with 3 screws. It senses the position of the egr valve.
