Sponsored by: Real Truck
Loose steering wheel
Old Jul 18, 2016 | 08:04 PM
btm991's Avatar
btm991
Hi all,
Is there a way to tighten the steering wheel? My issue is the steering wheel is physically loose, meaning I can wiggle it up and down when driving and when parked. Any help is greatly appreciated!
Old Jul 18, 2016 | 09:43 PM
cyncwby's Avatar
cyncwby
You don't say what year your's is but if you have an air bag then I think you would have to take it to someone who knows what they are doing. I personally wouldn't want to screw around with it and ruin the electrics to the bag or worse yet have it go BOOM.
Old Jul 19, 2016 | 02:24 AM
clem1226's Avatar
clem1226
Is the whole column loose or just the wheel have slop in it?
Do you use the wheel to pull yourself in to the truck when you get in?
Old Jul 19, 2016 | 10:59 AM
Mike1's Avatar
Mike1
If you attempt to work on it yourself, disconnect the battery, both posts, wait 15 minutes for all residual current to leave the system, then you can attempt it.
Old Jul 19, 2016 | 05:06 PM
btm991's Avatar
btm991
There is no slop in it while driving the wheel is actually just loose. And while I don't use it to pull myself to get in, some others in my family tend do. It's not the entire column only the wheel itself
btm991's Avatar
btm991
Thanks all for the warnings!
Old Jul 19, 2016 | 05:36 PM
SHAWZER's Avatar
SHAWZER
What year is your truck ?
Old Jul 19, 2016 | 05:40 PM
btm991's Avatar
btm991
It's a 2011
Old Jul 19, 2016 | 10:35 PM
clem1226's Avatar
clem1226
So there are two ( I believe) bearings in the column. Let's call the top one by the wheel outboard and the lower one inboard.
When nefarious family types pull themselves in to the truck using the wheel the outboard bearing gets crushed and you get a loose wheel.
about $230 will make her like new again. But you may be able to get just the bearing and tolerance sleeve.
http://www.steeringcolumnservices.com/ford/full-overhaul-kit.php
Check out this link to get an idea of what needs to be done
https://youtu.be/M1ciPtiSO5o
Old Jul 19, 2016 | 11:27 PM
351Cleveland C4's Avatar
351Cleveland C4
My 99 was like that. Upper bearing was bad and wore out the shaft. Had to tear it all apart, weld up the shaft and turn it down in my lathe, and replace the bearing. Above most people's abilities. Shop will probably replace the Column.
mesimpson66
Jul 22, 2011 08:05 AM
tehwarrior
1997 - 2003 F150
Nov 6, 2009 03:39 AM
Bernie Lomax
May 28, 2008 08:52 AM
LaredoF350
Jan 4, 2008 11:55 AM
894x2keith
Jul 9, 2000 11:20 PM
