Tail lights stuck
Old Jul 15, 2016 | 03:58 PM
Brianja27's Avatar
Brianja27
Tail lights stuck
Hi I'm new to this forum was looking for some help
I have a 1984 f250 and the tail lights are stuck on.
It's def not the brake lights because they light up brighter when I hit the brakes
I thought it may be the light switch so removed it and they are still on.
I would appreciate any help or direction
Thanks Brian
Old Jul 15, 2016 | 05:43 PM
FuzzFace2's Avatar
FuzzFace2
Brian, welcome to the forum.
So with the light switch un-plugged you say you still have the tail lights on?
Have you pulled all the fuses to see if they go out?
Did you do anything to the wiring before this happened?
Truck have a trailer light plug that may have power to charge trailer batt.?
If they come up with nothing you will have to trace up the wiring. I would start at the rear lights and work to the front till you find what is powering them.
Dave ----
Old Jul 15, 2016 | 06:00 PM
Brianja27's Avatar
Brianja27
I have done nothing to the wiring besides cut the speaker wire. I didn't know if it could be a ground issue
Old Jul 15, 2016 | 06:51 PM
Franklin2's Avatar
Franklin2
Start pulling fuses till they go out. That will give you a clue which circuit is feeding them.
Old Jul 15, 2016 | 08:40 PM
kr98664's Avatar
kr98664
Hiya Brian,
Welcome to the forum. Lots of smart, helpful people here. I'm here, too.
Take a look after dark. You may have other bulbs shining dimly that don't show up in the daylight.
Does the rear license plate light also come on?
Dual rear wheels? If I'm reading the diagram correctly, there's a marker lamp relay only used on duellies. That could be stuck on.
Dual batteries? If so, that changes some of the wiring.
To clarify, you said the tail lights are illuminated even with the light switch completely disconnected?
Old Jul 15, 2016 | 09:49 PM
Brianja27's Avatar
Brianja27
I could see the tail lights on the batteries went dead and it is not a dually but it does have dual batteries. This evening I went out there and the lights are out now and I plugged the switch back in and turned lights on and they lit up and turned off. This is odd to me and irritates me. I'm gonna try fuses tom if they are back on. Thanks for input. If you guys can think of anything I'll check it out. This is frustrating lol
patrickmcl
Nov 18, 2012 03:11 PM
Yougotthehit
29
Feb 21, 2010 06:39 PM
Aerocook
Aerostar
Jun 28, 2006 11:09 AM
gtrippleb
Nov 6, 2005 01:14 AM
wartz
Dec 28, 2003 12:26 PM
