tail lights
Old Dec 22, 2003 | 06:42 PM
wartz's Avatar
wartz
Unhappy tail lights
I am the owner of a 96 ford power stroke f250, 94000 miles. has a towing package. Tail lights quit working. Headlights, turnsignals, brake lights are all ok. Checked fuses,and power distribution box all are ok. Bought new tail light wiring harness which did not work. I get juice on a brown wire all the way back to the tail light plug. Also purchased new tail light bulbs. HELP!
Old Dec 22, 2003 | 06:47 PM
Quadzilla's Avatar
Quadzilla
Up underneath the spare tire, is the wiring harness for the trailer lights. You could always tap into the appropriate wire in the harness, and run it back to the tail lights on the truck.
Old Dec 22, 2003 | 06:48 PM
bcmmdl's Avatar
bcmmdl
Could it be possible that there is a problem with the switch on the dash? Just a thought.
Old Dec 22, 2003 | 06:59 PM
jharvey3's Avatar
jharvey3
Had the same prob on my xploder, headlights, turn signals, brakes worked but no dash or tail lights, replaced switch and voila' all was right again.
Old Dec 23, 2003 | 05:58 PM
wartz's Avatar
wartz
Thanks everyone I will check further!
Old Dec 23, 2003 | 10:05 PM
horsecop's Avatar
horsecop
If brake lights don't work and everything else does, check turn signal switch in column. When the steering wheel is pulled down the harness will pull loose enough to cause the rear lights not to work. 96's were bad about this. 2cent zip tie cured mine. Hope that's it.
Oh, Merry Christmas Quad
Old Dec 28, 2003 | 12:26 PM
wartz's Avatar
wartz
That's worth a try. Still working on the problem.I keep thinking it's just something I've overlooked. I'll keep you posted.
brcwelding
Nov 13, 2011 08:55 AM
F250GH
May 14, 2009 08:01 PM
rcraig
Sep 9, 2007 06:16 PM
vancouverpower
Jan 27, 2006 10:48 PM
