Easy-Out
Old Jul 30, 2016 | 02:30 PM
daveengelson's Avatar
daveengelson
Appreciate comments: Yes, found when I take short cuts it usually turns out bad; basically came down to taking steps for a possibly better outcome, or risk having to remove the head. Intend checking torque on couple occasions over next 2-3 week, perhaps prevent the other shoe from droppings
Old Jul 30, 2016 | 08:14 PM
baddad457's Avatar
baddad457
Shouldn't need to do that. When I torque a small block intake down, I keep going round the sequence until the gaskets are fully compressed. Then recheck it one more time an hour or so later. Once this is done the bolts should stay torqued to spec.
Old Jul 31, 2016 | 01:49 AM
xlt4wd90's Avatar
xlt4wd90
Originally Posted by baddad457
Doesn't matter about the dwell, the timing's going to be exactly where you set the marks at. The dwell does matter as far as point settings goes. This trick works with electronic igniton as well.
Sorry, forgot we were talking about a modern engine. The last time I did this was on my 69 Mustang, which had some dwell angle. This meant the spark starts right when the points opened when you turned the cap CW, but if you did it turning the cap CCW, it would be way too early. But all moot now.
bryan_johnson
18
Mar 3, 2019 09:13 AM
ChristopherN
Jul 7, 2011 10:01 PM
91gettaDI
16
Nov 1, 2009 06:46 PM
neevnav
Apr 14, 2007 07:55 PM
farmerboy
Mar 31, 2006 07:17 PM
