its an 88 f150 5.0, everything is removed from the upper intake manifold but there is still something holding it up, i found a bolt inside under where the manifold hangs over, what kind of bolt is that? i cant get an allen on it... this is driving me crazy... help?
it's a torx bolt -dead in the middle of the intake right?
I HAVE SEEN THE LIGHT! yea so im an idiot i did not even notice the slit from the other side that i can access the bolt from... thanks for the help guess, sometimes i just dont see things
ok i found the opening, but now i cannot get my torx bit to fit through the opening, and i after putting the torx bit under the manifold, and then meeting it up to the extension it is apparently too long to make it to the head of the bolt
I use a cut off, long torx T handle with the T cut off and the shank installed into a small socket (cant remember the size)............That will get you right in there, but it might require a trip to the AP store if you do not have a T-45 torx T handle to sacrifice.
I used a T-45 in a changeable bit screwdriver with a long shaft on it. The end of the screwdriver was magnetized for holding bits and bolts in place- worked great for removal and installation. You can't torque it to spec on installation, but I just tightened down as hard as I could- no problems after a year.
