2012 Explorer Braking Issue
Old Jul 15, 2016 | 08:18 AM
bulldogcountry1's Avatar
bulldogcountry1
I have a 2012 Explorer Limited with 95K miles. Under medium to hard braking, the steering wheel wobbles, and the car slows irregularly. I'm struggling to find the best word to describe. It's not a vibration or a shudder. It's like a pulsing that is slow enough to be counted. The car doesn't pull to a side under braking, either.
I put a dial indicator on both rotors, and they are nearly perfectly flat. There is no evidence of a leak anywhere. The only think I noticed is that the DS caliper had a little more pressure on the rotor, making the rotor harder to turn than the PS rotor.
Old Jul 15, 2016 | 12:47 PM
shorod's Avatar
shorod
A brake pedal pulsation under braking is almost certainly due to a rotor that is either warped or not running true. It doesn't take must to cause it either, just a few thousandths of an inch can cause a noticeable pedal pulsation. And if you're absolutely certain that there is no measurable runout on the inner or outer brake rotor surfaces, then you may either have a surface contamination or something stuck between the rotor hat and the hub that is causing the rotor or rotors to not run true. If the wheels were loosened just prior to this happening, rust may have fallen from the rotor vents to the hub.
-Rod
Old Jul 18, 2016 | 09:44 AM
bulldogcountry1
After merely taking the front wheels off and measuring the rotors, the pulsing has reduced about 80% (at least for now). There is still some still some steering wheel wobble, but the pulsing is barely felt until the car almost gets to a complete stop.
Gotta love intermittent problems.
Old Jul 18, 2016 | 11:50 AM
shorod's Avatar
shorod
With that information I'd be very suspicious of rust or other debris that was sandwiched between the rotor had and the hub. When you removed the wheel the debris would have had an opportunity to drop out with gravity's help.
-Rod
MilllerTime
2004 - 2008 F150
Dec 27, 2013 05:07 PM
hdman6
Mar 27, 2011 06:07 PM
DLogan
Mar 19, 2011 01:34 PM
AF Mezkin
Mar 15, 2007 11:59 AM
Flabiker3
Aug 16, 2003 07:18 AM
