Turbo issue??
Old Jul 13, 2016 | 05:30 PM
Jeffkniseley's Avatar
Jeffkniseley
Turbo issue??
So I am not sure exactly what is going on with my truck. It is a 2004 F250 has a 6.0 L.
Sometimes when I take off from a stop the truck has no power and blows some blacks home. Then the turbo kicks in and all is fine. It comes and goes when it pleases no matter the temperature. What started happening is when I drive it a steady pace on the highway sometimes the turbo gets quieter and louder and quieter and louder sometimes when it gets quieter I see a little bit of black coming out of the tailpipe. Sometimes it doesn't do it at all.
Also sometimes when I let off the gas the truck sounds like it's trying to laugh at me like a wastegate is fluttering.
Old Jul 13, 2016 | 07:13 PM
r2millers's Avatar
r2millers
You need to pull any codes off your obd connection. You very well might have a stuck unison ring in an overboost position to create that waste gate sound, even though you don't have one.
Live data help even more, vgt's command. Also pull your baro, egt, and map #'s at key on, engine off.
You should see similar readings although, don't be fooled by psi vs hg's of mercury when comparing.
Old Jul 13, 2016 | 08:53 PM
Jeffkniseley
There is no codes
Old Jul 13, 2016 | 09:16 PM
FordBlueHeart's Avatar
FordBlueHeart
Originally Posted by Jeffkniseley
There is no codes
Ok, we're going to need more info here. What did you try to pull codes with? Are you monitoring anything? With what device? What values are you seeing?
Old Jul 13, 2016 | 09:33 PM
87crewdually's Avatar
87crewdually
Have you ever had the turbo removed and cleaned? Sounds like a sticking or wore unison ring.
What are the boost readings doing when this occurs?
Old Jul 13, 2016 | 10:45 PM
Jeffkniseley
The napa here has a snap-on scanner. There where no codes. As for boost pressure I don't know there is no gauge.
I will poast a video up as soon as it loads on photo bucket.
Old Jul 14, 2016 | 12:13 PM
FordBlueHeart
One of the most important things that will go a long way to diagnosing your issues and keeping the truck operating properly is a monitoring device.
There's several different options depending on what your intentions are with the truck or your budget.
Old Jul 23, 2016 | 03:03 PM
LindenBruce's Avatar
LindenBruce
I'm having a similar issue. Started several days ago with no to very little boost during acceleration. No black smoke or unusual exhaust emissions. Atles 40 tune in FICM. The problem happened several times. Fired up OBD Link and had a look. When the problem would arise she was only generating 7-9 psi boost under full throttle.
Ran some numbers today.
Cold VGT at 75% at idle with .6-.8psi boost and cruise 54% with 5-7psi boost.
Hot VGT at 63-68% at idle and cruise at 45%.
Operating temp normal acceleration from stop VGT 38-41%.
Operating temp full throttle from stop VGT 35-55% and MAF at 35.7lb/min
Operating temp steady 55 MPH VGT 45-50% and MAF at 10/7lb/min.
NO TROUBLE CODES.
132K+ miles.
Turbo was removed and cleaned about 50k ago.
So the only thing is, is intermittent low boost with PSI below 9 when it does happen and engine will gain full RPM's but very light acceleration at the same time. Almost like the transmission is slipping, but it is not. Recently did dummy plugs and stand pipes.
I suspect a sticking unison ring. What is the consensus guys? Bruce
Old Jul 24, 2016 | 12:15 AM
r2millers's Avatar
r2millers
Check your MAP hose that runs down to your pass side valve cover. They are known to split, crack, and create havoc when they get rotten from high temps right at the connection.
Easy thing to check and replace. I don't think it sounds like the unison ring based on your vgt command numbers.
Old Jul 24, 2016 | 01:01 AM
LindenBruce
WOW, good idea thanks. I would never have thought about the MAP hose. B.
Old Jul 24, 2016 | 02:01 PM
LindenBruce
Well, I pulled my MAP sensor and hose off today. The exterior of the hose looked fine. I tried to vacuum test it and the assembly would not hold a vacuum. Changed out the hose and vacuum tested again. This time it DID hold a vacuum. I re-installed the MAP and hose assembly. Did not take it for a test drive yet today. Will see how she runs this week.
Here is a pic of the hose. The end view was at the intake manifold side. You can see some cracks along the interior section of the hose. The exterior still looks fine. It was too short to cut and reuse.
Thanks for the tip Bob. B.
Bad Brad
6.4L Power Stroke Diesel
Jun 17, 2014 01:12 PM
RLB112
Apr 8, 2010 11:26 AM
smagma
Jun 26, 2008 03:15 PM
orangebyke
Dec 29, 2007 03:47 PM
