2001 F-150 won't start (anti theft related)
Old 07-12-2016, 07:45 PM
Crd16's Avatar
Crd16
Crd16 is offline
My 2001 f150 is not starting up. The anti theft light flashes and then eventually slows down and flashes one time, pauses and then flashes two more times. The odometer still shows my mileage as I know some people with this issue just get dashes. I know there are passive anti theft codes that can indicate what is wrong but cant find a chart with any info for all the codes. I'm going to assume my pats transceiver module is shot. Or maybe the key simply needs to be reprogrammed? I've seen people say that before. Just hoping it doesn't cost an arm and a leg. I checked fuses, relays, etc and didn't see any that were blown. anyone have any ideas on what could be causing it? Or maybe there's a relay I forgot to check out. Just seeing what all possible help I could get on the issue. Thank you, I'm just lost on this
Old 07-12-2016, 08:36 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
put the key in the ignition and turn it on... not START... the light will come on, then go out in 3 seconds.. If the light does not go out, the PATS does not recognize the key.. Key bad or PATS bad.
Old 07-12-2016, 10:24 PM
Crd16's Avatar
Crd16
Crd16 is offline
I've already done that. That's the reason I put that my anti theft light continues to flash once, pause and then flash two times. I doubt it's a bad key as the spare does it as well. I'm guessing my pat module is shot. Getting a new one is cheap and easy. But then I'll need it reprogrammed to work with my existing keys. Does only ford do this? Or is there somewhere else that can do a pat relearn?
Old 07-13-2016, 07:24 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Ford does not document the lamp flash codes in their North American service documentation although they do in their UK service docs. In those, an LFC 12 indicates a problem with the transceiver. Whether this is the same as for yours is unknown.
Put the cluster into HEC Dealer Test Mode (Google it) and pull the DTCs. PATS-related codes are generally in the B16xx range. Report your results.
The '01 F150 does not have a "PATS module". You have the PCM and instrument cluster, a transceiver mounted around the ignition cylinder, and your keys. Only the transceiver can be replaced without reprogramming of the system.
Old 07-14-2016, 09:26 PM
Crd16's Avatar
Crd16
Crd16 is offline
I put the truck into HEC and was able to diagnose the problem. I hadn't thought of that.. It was a faulty transceiver. Picked up a new one and everything is good again
Old 07-14-2016, 09:47 PM
projectSHO89
What was the HEC DTC?
Old 08-09-2016, 03:54 PM
Crd16's Avatar
Crd16
Crd16 is offline
Don't recall the exact code but it was for a faulty transceiver
GirouxBodyShop
2004 - 2008 F150
13
12-20-2022 10:17 AM
PDS
6.4L Power Stroke Diesel
22
02-07-2022 11:19 AM
BigE383
1983 - 2012 Ranger & B-Series
26
05-20-2016 10:34 AM
jhuggs82
09-10-2015 10:15 AM
idagal
1997 - 2003 F150
02-26-2007 11:24 PM
Quick Reply: 2001 F-150 won't start (anti theft related)
