Nice Whistle
Old Jul 11, 2016 | 09:03 PM
jofes's Avatar
jofes
Nice Whistle
My 69 240 I6 has started whistling after I get up past 50mph.
If im speeding up it goes away, but after I let off just a little I get a nice loud whistle again. When I shut the truck off it goes away and does not come back tell I get it back up to speed. any thoughts?
Old Jul 11, 2016 | 09:21 PM
HIO Silver's Avatar
HIO Silver
Not much to go on... Can you clue us in on where it **might** be coming from? Front, back, underneath??????????????????
Is it a whistle like an air leak or more of a sustained screech???
I'm thinking a loose or glazed drive belt but dunno.......
Old Jul 11, 2016 | 09:35 PM
jofes's Avatar
jofes
Sounds like an air leak in the area of the carburetor. It stays whistling until I shut it off and then when I restart it, it is quiet until I get to higher speeds.
Old Jul 11, 2016 | 10:10 PM
HIO Silver's Avatar
HIO Silver
Check (look and feel) for a cracked hose or loose hose clamp/vacuum hose connection.
Old Jul 11, 2016 | 10:50 PM
70FE250's Avatar
70FE250
Sounds like a vacuum leak as HIO said. But a whistle from a vacuum leaks is pretty weird. Spray some carb cleaner around the base and vacuum lines of your carb and note of any idle changes and for the whistling to stop.
Assuming it is a vacuum leak it seems to be from the heat of the engine causing expansion of some sort
Old Jul 12, 2016 | 02:45 AM
GaryKip's Avatar
GaryKip
What tune is it whistling? Sorry, I got carried away. IF it's not around the carb (Spacer gasket?) AND the vacuum lines and caps are good, then check the belts and the pulleys. Check the water pump for a leak around the shaft (maybe the bearing is going bad?). I like the whistling tune in the latest Maytag commercial, now I can't get it out of my head.
Old Jul 12, 2016 | 06:50 AM
Brian1971f100's Avatar
Brian1971f100
Both my 95 f150 300 I6 and my 94 Bronco 5.0 had a whistle but only when temps below 20 deg. I think its a Ford thing. Something I never figured out.
Old Jul 12, 2016 | 12:25 PM
greasy rider's Avatar
greasy rider
+1
I had this once and it turned out to be one bolt holding the carb down had loosened enough to allow it to suck air in at that corner and cause a whistle.
Old Jul 12, 2016 | 12:43 PM
351Cleveland C4's Avatar
351Cleveland C4
It's your turbocharger. High speed = high boost.
Old Jul 13, 2016 | 09:04 PM
GLR's Avatar
GLR
Ran across something similar with a 84 300 . T'was the PCV valve.
GeneLaw1
Oct 16, 2012 09:42 PM
alvald83
Aug 28, 2010 09:23 PM
boffah
Jan 19, 2009 04:21 PM
jhand124
Jan 6, 2008 09:23 AM
scottlane
Nov 4, 2006 04:58 PM
