CCV bockage/frozen=Oil leak?
Anyone have this happen? Seal bust or leak? I had a turbo pedestal o-ring leak that happened a couple days after a accident I was in, it was pretty cold those few days. The weird thing is, after I got the truck back from the body shop, where it sat inside for a week and a half the leak stopped. I replaced the o-rings anyway.
Even though I'm not positive was caused the leak, I'm concerned it might happen again, I checked the hose for low spots and didn't find any and it's running down hill as much as it can. I can feel gases coming out, but don't get much if any steam and I can't smell it at the back of the truck like I used to when it was warmer. Is this normal, would I get more steam if the air was more humid? I'm probably going to cut the hose at the cab to make sure the vapors are draining and not condensing and freezing and then reconnect in the Spring. Thanks for any input.
Can't hurt to cut the hose on the downhill side and check for flow. A simple heater hose coupler puts it back together. You could also disconnect the hose from the dog house and simply check for flow there, and reconnect. My CCV hose is getting kinda ratty. Seems to be getting saturated with oil vapor and is not long for replacement. Still flows good though, just getting real spongy and oily on the outside.
Thanks for your input, I know the possibility of increased pressure could result in a leak. Does anyone know of someone where this has happened? I agree with kwik, I think the long hose is increasing resistance and if there are any pools of condesation they are acting like a plaque in an artery thus increasing pressure. My truck might have high blood pressure. Thanks
Well I for one have actually had this happen. A couple of weeks ago it started getting below freezing, and I noticed the truck wasen't running very well. Then I noticed quite a bit of oil when she was running, dripping down from somewhere. So after a little investigation I found that the dipstick was actually blown out a little and oil was comming out from there. Then I got to thinking how in the He(( is this happening. Then I thought about the CCV Mod. When I looked at the end of the hose ( over the rear axle ) I didn't notice any vapor. So I turned the truck off , crawled under the truck and below the drivers door I had a coupler in the line. I removed the hose and, woosh air escaped. I guess somewhere where it runs down the frame rail it was frozen. I'll just left the hose disconnected under the cab till spring.
on
I think what is happening here is that when you run the hose for a long distance towards the back of the truck, you might get low spot or like a "p trap" on a sink drain and this will collect moisture and oil, blocking off your breathing system..
I made sure mine was on a gradual down hill angle on the hose..
on
I read about this happening to someone else on this forum and about two days latter the same thing happened to me so I cut mine off under the cab and have not had any problems since. Every once in a while I get a wiff of some fumes but most times the window is up anyways it hasn't been a problem.
