Vibration
Old Jul 11, 2016 | 10:59 AM
beartracks's Avatar
beartracks
Vibration
I've been chasing a weird vibration for a long time. Been through all the usual suspect i.e. drive shaft, angle, "U" joints, tires, wheel bearings and more. I've started to blame it on the transmission but it has good fluid and no other problems. Starts about 60mph and kinda runs all through the truck.
I occurred to me in the middle of the night that I once broke an axle right at the bearing and the wheel, hub and bearing left for parts unknown. I wasn't going fast at all when it happened but the truck did drop on the housing/brake backing plate. Some idiot overheated the axle to get the bearing off.
Any ideas on how to check for straightness or how much will cause probs?
Old Jul 11, 2016 | 11:56 AM
Tedster9's Avatar
Tedster9
Center support bearing changed out? Just about every old truck I've seen, these bearings are always lunched. This will noticeably degrade noise and vibration levels at highway speeds, heck even if that's not the problem here it's worth replacing.
Old Jul 11, 2016 | 11:57 AM
Filthy Beast's Avatar
Filthy Beast
I would start by checking the next obvious on the list - the tires. If a belt has broke you'll get a vibration. A "hump" in the offending tire/tires will be observable if you look close.
On checking the axles, other than pulling one and looking, I'm at a loss.
Ajlowry
Mar 12, 2019 07:14 AM
CrazyMiracleMan
1983 - 2012 Ranger & B-Series
19
Dec 15, 2011 11:30 PM
georgiabuck
Aug 19, 2010 11:13 AM
powerstroke6ltr
Mar 6, 2008 08:38 AM
OAGES
Jun 13, 2004 09:40 PM
