grinding/vibration
Old Mar 5, 2008 | 09:44 PM
powerstroke6ltr's Avatar
powerstroke6ltr
grinding/vibration
I did a search and couldn't find the exact symptoms i have. I get a grinding/hummin noise at around 70+ mph and then a coarse vibration below 15... tires are pretty agressive, and the grinding comes and goes... any ideas? thanks!
Old Mar 5, 2008 | 09:48 PM
f350rebel's Avatar
f350rebel
are your tires cupping in the front... if they are try rotating them this may get rid of some of the vibration
Old Mar 5, 2008 | 09:50 PM
Kwikkordead's Avatar
Kwikkordead
Front wheel bearing.
Old Mar 5, 2008 | 10:39 PM
powerstroke6ltr
the fronts are wearing a bit funny... shouldn't be ball joints... how hard are front wheel bearing replacements and can i just replace the bearing or do i have to get a whole new hub assembly?
Old Mar 6, 2008 | 08:34 AM
Kwikkordead
You have to get the whole hub assembly. It's an easy job, but first verify the bearing by raising the front end off the ground and see what the wheel sounds like when it spins. A bad bearing will rumble, wheel will feel loose or both.
Removing the hub requires that you remove the brake caliper and rotor. Then the axle comes out, (MUCH easier than it looks).
Then unbolt the four nuts on the inside of the spindle and work the hub assembly off.
Old Mar 6, 2008 | 08:38 AM
someotherPSD's Avatar
someotherPSD
Kwik's got you covered on this. Very simple job.
Mazellan819
May 7, 2012 12:21 AM
ranchers_wife
May 15, 2010 02:14 PM
Jbru167
Feb 4, 2009 05:18 PM
Jimmygunz3
Aug 27, 2007 12:37 PM
rett8799
1978 - 1996 Big Bronco
Mar 13, 2004 05:56 PM
