Need conversion u-joint for engine/tranny swap
Old Jul 10, 2016 | 08:53 PM
choptop49ford's Avatar
choptop49ford
Spent the weekend pulling the 360/manual out of my f100 and replacing it with a 460/c6. Engine and tranny are in with the exception of relocating the tranny crossmember mounting holes, didn't expect to but both sets are to far forward. Here's the problem, the drive shaft is set up for the manual/9". The shaft is to long, not an issue, I've cut down and re welded several while maintaining the proper balance but the manual slip yolk is to small for the c6 output shaft. I have the correct yolk but the u joints are different. What I need is a u joint to mate the new yolk to the old shaft. I haven't pulled the old joint out to mic it yet but thought someone may have already done the swap. I'll measure and post in the morning if need be. Not a joint expert but the c6 uses the same joint as several of my 4wd Fords, I belive a 1350 joint. I belive the existing joint is a 1330, not sure, smaller than I'm used to.
1976 f100 sb 2wd
Originally 360 with 3.03 manual
Now 460 with c6
9" rear
Old Jul 10, 2016 | 09:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you do need a 1330/1350 conversion joint, Summit has them.
Moog number is 448.
https://www.summitracing.com/parts/mog-448/overview/
Old Jul 10, 2016 | 09:43 PM
79finally's Avatar
79finally
I used the chart in the link to figure out what my joints were.
My 205 tcase has 1330s
Rearend in highboy has 1330s
2wd auto rear driveshaft had 1330(don't know year)
1997 f350 front axle has 1330 BC(big cap)
Not sure when Ford used 1350 joints as all mine were 1330
U-Joint series identification
Old Jul 10, 2016 | 10:20 PM
davewild's Avatar
davewild
Spicer's website has a sweet lookup tool to find the right u-joint
Measuring U-Joints
Old Jul 11, 2016 | 01:34 PM
choptop49ford
Thanks for the charts guys. I need a 1310/1330 joint. Time to shop.
Old Jul 11, 2016 | 01:51 PM
choptop49ford
Moog 253
Performance dynamics 2-0344
Neapco 1-0134
Spicer 5-134x
These are the most common brands and their part numbers for a 1310/1330 combination joint that I found.
Old Jul 11, 2016 | 06:39 PM
davewild's Avatar
davewild
I have a brand new one I don't need......rather see it used than sit on a shelf. It's just been installed for mock up then I changed driveshafts.
Old Jul 12, 2016 | 12:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-4635-F .. U-Joint - 2 cups are 1310's, 2 cups are 1330's / Spicer: 210392-X / Obsolete ~ Available from auto parts stores.
swampthang
Mar 23, 2018 10:30 AM
phil75j
Mar 1, 2014 08:56 PM
impalaslayer
Feb 26, 2013 07:52 PM
Voh
Nov 30, 2006 02:17 PM
duece-bigalo01
May 9, 2004 03:05 PM
