1979 front dana 44 help
Old Feb 26, 2014 | 09:41 PM
phil75j's Avatar
phil75j
Howdy, i have my 79 short-wide 4x4 with a little problem. After i bought and rebuilt a front driveshaft, i discovered that the yokes on the t/c and front diff arent set up to receive a CV joint. Also even if the t/c could bolt to it there is not enough clearance for the H-yolk to spin without hitting the tranny pan, it's a C-6 auto. My question is can i get a spindle yoke to fit at the front diff to receive a CV joint? If so where can i get one? Thanks for any help.
Old Feb 27, 2014 | 10:35 AM
bpete's Avatar
bpete
I assume you have a C-6 transmission. What about your t/c? is it a 205 or 203(full time 4x4) ? When you say set up for a cv do you mean bolt hole in yolk are threaded? You may have a t/c out of a Bronco that would have used a cv at the t/c. I wouldn't thin that your differential yolk would be made for a cv joint. Best bet would be getting correct yolks for the drive shaft you had rebuilt. They would be available new or used. Make sure you get the correct ujoint size also.
Old Feb 27, 2014 | 01:37 PM
phil75j's Avatar
phil75j
n/p 205. the truck is the same as when i bought it. not sure where they got the parts. the tranny was damaged by the front driveshaft CV joint before i bought it so i know it was a problem before i got it. i replaced the tranny and i found that the previous owner just "rigged" the driveshaft to fit with U-bolts instead of using the center yoke of the CV joint with straight bolts.
Old Mar 1, 2014 | 11:10 AM
bpete's Avatar
bpete
I might be wrong but I don't remember a pu having a cv joint in the front drive shaft. Possibly a full time 203 tc did not the 205's. I do think some broncos with a 205 had a cv in the front shaft though. Is it possible that drive shaft needs flipped end for end? Putting slip yolk by front differential. I am sure there is someone here that would know for sure. I have some 78 & 9 F150 and broncos I will look at, but not today 9 degrees outside with snow and wind lol.
Old Mar 1, 2014 | 11:55 AM
phil75j's Avatar
phil75j
Thanks for checking for me. It's looking like I may have to just have one built to fit the truck though. But I didn't want to spend several hundred dollars on a font D/S
Old Mar 1, 2014 | 08:56 PM
tabascom16's Avatar
tabascom16
There is two versions of yokes. One to accept a double cardan joint and has threaded holes (the double u-joint part of the driveshaft...it is technically not a CV joint but most people call it one). The second is a yoke with unthreaded holes to accept just a single u-joint.
My 79 F250 with C6 and D44 front had double cardan joint on the front drive shaft, yet the 79F250 I bought for a D60 front end only had single u-joints on both sides of the driveshaft. With the D60 and manual tranny the front driveshaft is a few inches smaller than the C6 (longer than the T18) and D44. You would think the shorter driveshaft would have had the double cardan joint.
I have no reason to suspect these had been altered over the years but you never know. If they were factory from Ford I have no idea what criteria they used to use a single u-joint or double cardan joint.
I am sure you can find one from somebody on this site or someone local to you.
lastclodstanding
Jan 25, 2012 07:32 AM
cabloom300
18
Aug 30, 2011 05:45 PM
clhart426
May 17, 2011 03:19 PM
bigbadbaj4x4
Jan 3, 2003 10:38 PM
dj9124
Jan 22, 2002 04:42 PM
