E99 Belt Tensioner
Old Jul 9, 2016 | 02:16 PM
1L243's Avatar
1L243
E99 Belt Tensioner
I am in the process of changing my serpentine belt on my W99and thought I would replace the Tensioner as well. My question is that there is a spacer bar on the new Tensioner and there wasn't one on the old Tensioner. Can someone tell me what this is?
Thanks
New
Old
Old Jul 9, 2016 | 02:18 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Edited due to the correct answer from Pikachu.
Old Jul 9, 2016 | 02:21 PM
1L243's Avatar
1L243
Thanks I was thinking that but did not want pull it out of there till I was sure..
MIGHT ADD UNDER EXTREME PRESSURE! THING SHOT ACROSS THE ROOM!! LOL
Old Jul 9, 2016 | 03:35 PM
Pikachu's Avatar
Pikachu
You aren't supposed to remove it. You leave it exactly as it is, install the tensioner and the belt. Then put your 1/2" drive breaker bar or ratchet in the hole, push it toward the passenger side fender and the lock will release. If you need to remove the belt in the future, it's still there to lock the tensioner again.
Old Jul 9, 2016 | 03:38 PM
1L243's Avatar
1L243
Thanks for that info but I already sent that sucker across the garage. Luckily it missed the window
Militant83
Jun 18, 2014 01:09 PM
smacDiesel
Nov 8, 2013 03:44 PM
KINGDAR
May 29, 2012 04:10 PM
Piolet
May 14, 2012 05:48 PM
LUMBERMAN
Jan 23, 2011 03:07 PM
