Just need some advice on how to safely lift the body off my bronco and pull the frame out form underneath it. Suggestions, pictures of your body/frame disassembly would be much appreciated
W E L C O M E !!!
to the best forum on FTE!
not a lot of action here but many good guys who have alot of experience & R willing to share it.
The frnt (body mount 1 to #2) is very wimpy. The fenders R the only solid prt to hold things together & that is NOT good enuff to hold things together for ur purpose (removal). If unsupported that area can crumple like a sheet of tin foil. Doors will B very difficult to align. If U R going to the "rotisserie" remove the doors, 1) tack some 1/2 inch channel across the door hinge to pillar posts @ top and 2) a 3rd all the way across the body from driver's door to passenger's door. Create supports on the rotisserie that support both the #1 and #2 body mounts. Then it is safe to remove body & hang.
I don't have time tools or funds to do any of this so am planning how to take care of the same issue while inserting WH's BL. I believe there is less chance of damage with this procedure but still think that removing all old BL 1st, then replacing all in the next step will require cross frame/body "blocks" to level/maintain hight so as not damage fenders/door alignment.
Weld some angle iron in the door openings. I ran one piece across near the top of the door opening and then one at an angle. Without the one at an angle the body can still flex and bend.
I then bolted a 2x4 under the top lip of the quarter panels with the bolt holes that the top goes in as close to the rear door posts as possible. I then put an eye bolt in the center of the 2x4 and lifted with an engine hoist. In this setup it is front heavy but a single person can hold the front up while someone rolls the frame out from underneath. Then just lower the body onto saw horses.
I get some strong cautions against that on several bronk specific sites over these last 25 yrs (1st mounts-begin. Of frnt end to body mounts @ floor boards-2nd mounts).
I may B reading them wrong, but that's my feeling. I have not gone thru this procedure so will defer to you & your experience. I wonder if it's an on/off confusion I have regarding the fenders. May B 'on' they create the problem rather than 'off'…that doesn't seem right.
Wishing it were so, sending the e-mail in my sig for any pic you offer…
Can't post them up here 4 the original thread poster?
FTE is an awesome place overall, but unfortunately not a ton of super experienced EB guys on here. Here is a web site that has a TON of EB ONLY experience on it.
I have not pulled a body myself, one Bronco is already beat up and I am off roading it as is. The other does NOT even have a body, tube buggy!
I have seen lots of pics and info on the CB site about this, and that is why I suggested it.
But if I was going to pull a body, I would take off as many parts, pieces and panels that I could. X brace the doors and the rear part of the tub and make a jig to set it in to replace rusty panels.
