The Hillbilly Stretch-Limo (my 6-door Superduty project)
#64
#68
#70
I fixed some of the redneck hackery today. I installed stainless intercooler pipes on the hiphopopotamus:
No more boost leak. It cut down on the smoke dramatically. I will still need to pull the heads when I yank the engine, to fix the low compression on #8, I don't know if I'll get any truck project time this weekend, my wife has a triathlon on Saturday and she wants me to "support" her.
#71
#72
#73
Some of you may remember my old truck, an 02 F350 CCSB 4x4 powerstroke. It was ugly and mean, almost perfect! But then a drunk driver ran a red light doing 80mph and annihilated it (along with my left arm.)
https://www.ford-trucks.com/forums/1...superduty.html
I'm mostly healed up, I have a kinder, gentler 02 F350, and I'm itching for a new project. So far I have a 6-door cab built from the front of an 06 lariat and the back of an 02 xlt. I traded some guns for this and it's pretty good, not perfect. The door gaps are spot on, but the welds aren't as pretty as I'd like:
I have the frame from an 09 crew cab short bed, and another frame from a 2000 crew cab short bed:
Finally I found the drivetrain donor: The Hiphopopotamus, a 2006 F550 with a 6.0 PSD:
This is going to be a ton of work, but also a ton of fun!
#75
I got the frame reinforcements from the machine shop today:
I had them built from 1/4" plate that was bent on a brake to fit snugly inside the original frame rails, but instead of nesting them inside the frame like I've seen done on other trucks like this, we reversed them to form a box. This will cause me a lot more work when it comes time to mount the brake lines, fuel lines and exhaust, but the added strength will be worth it.
We also drove the 550 over to my friend's shop to begin the teardown and part out.
