Sponsored by: Auxito
front dif removal
Old Jul 7, 2016 | 08:27 PM
bigcrunch's Avatar
bigcrunch
front dif removal
Front axle differential\axle housing removal from a 98, other than pulling CVs what's involved? I have never done this generation and it is about an hour away I want to be prepared when I get there.
Old Jul 8, 2016 | 09:29 PM
steve(ill)'s Avatar
steve(ill)
I have never done it either, but the half shaft/ CV joint unit is flanged on the inner end and has 4 small bolts to hold it to the differential......... The differential is mounted with 3-4 rubber mounted bolts to the frame. Again, I have not removed one, but seem to remember the bolts being about 12-14 mm ..... so the sockets are probably in the 17- 21 mm range. .......... not sure about the access to a couple of the bolts.. big punch and hammer maybe, and a floor jack.
Badmoonreizen
24
Dec 14, 2016 07:24 AM
4x4countryboy
May 11, 2012 12:03 AM
1979390
Apr 10, 2007 04:42 AM
sc93f
May 4, 2006 08:35 PM
sancochojoe
Paint & Bodywork
Jan 30, 2004 07:48 AM
