I have been looking online for quite some time and this page seems to have lots of the answers i was hoping for. When i started trying to decode the vin i was sure it was a 1966 but the more i read into and look at the plate I'm not convinced. I have read many threads on here about the hard time the Canadian vin plates have provided and i called Ford Canada to see if i could get some further insight (left a message)
what i do now is its a F-350 with a 9 foot box it is red and i think it has the Inline 6 300
6993532L-205215B
When I started trying to decode the VIN .. I was sure it was a 1966, but the more I read into and look at the plate, I'm not convinced. It's not a 1966.
What I do know, it's an F350 with a 9' Styleside Express box, it's red with the 300 I-6.
6993532L-205215B
Welcome to FTE
240/300 I-6's introduced in 1965, have the intake & exhaust manifolds on the right (passenger) side.
It's a 1965. It's not a 1966 because 1966 Canadian trucks use the same (11 digit) VIN and Warranty Plate as US trucks.
6 = 6 Cylinder Engine.
99 = Styleside Pickup.
35 = 350 series.
32 = 132" wheelbase.
L = Left Hand Drive.
205215 = 1965 Numerical Sequence of Assembly, the trucks specific serial number.
B = 6100-10000 lbs. GVWR
TRIM: 05 = Red Crush Vinyl & Red Wicker Pattern Vinyl (81A Standard Cab).
PAINT: RR = Red (exterior paint color-Canada only).
AXLE RATIO: 5.13-1 = Spicer/Dana 70 Rear Axle.
SERIES: F350.
W.B. 132
MAX GVW LBS: 8,000 lbs. Gross Vehicle Weight Rating.
ENGINE: SQ = 300 1V I-6.
TRANS: New Process 435 4 Speed Manual Transmission.
Thank you so much Numberdummy! I appreciate the prompt reply, It helps =D I'm hoping to get some parts and get it running again. I thought it was interesting it has Ford loopy company logo and not the block letters i usually see.
Canadian-Built Ford and Mercury Truck Data: '61 --> '64 VIN Decoding
daemondea: Here is a link containing the front pages of the pre '65 CDN Ford/Mercury Shop Manuals. The front pages are where you will find the info to decode the Warranty Plates.....
Thanks James thats helps if we have to do another truck. it has the same plate thats the 1964 truck shows maybe its a strange cross year? I will get around to posting more pictures today hopefully!
