VIN decode.
Old Dec 9, 2014 | 07:59 PM
Argie66's Avatar
Argie66
Trailering
VIN decode.
Hi guys, me again..... will any of you be able to decode this vin?
F10BK890XXX
115 8M F100 D81 G 17
05000 150 3600 65
Thanks in advance!
WebRep
[IMG]chrome://wrc/skin/png/line-dark-horizontal.png[/IMG]Overall rating
<img id="wrccat_shopping" height="30" width="30"><img id="wrccat_social" height="30" width="30"><img id="wrccat_news" height="30" width="30"><img id="wrccat_it" height="30" width="30"><img id="wrccat_corporate" height="30" width="30">
<img id="wrccat_pornography" height="30" width="30"><img id="wrccat_violence" height="30" width="30"><img id="wrccat_gambling" height="30" width="30"><img id="wrccat_drugs" height="30" width="30"><img id="wrccat_illegal" height="30" width="30">
Old Dec 10, 2014 | 02:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Argie66
F10BK890XXX / WB: 115 / COLOR: 8M / MODEL: F100 / BODY: D81 / TRANS: G / AXLE: 17 / MAX GVW LBS: 05000 / CERT. NET HP: 150 / RPM: 3600 / DSO: 65
F10 = F100 2WD
B = 300 1V I-6.
K = Kansas City MO Assembly Plant.
890XXX = 1966, assembled July 1966.
115" Wheelbase.
8M: 8 = Springtime Yellow / M = Wimbledon White.
F100 2WD, 5,000 lbs. GVWR
D81: D = Medium Beige Crush Vinyl & Medium Beige Cody Pattern Woven Plastic / 81 = 81B Custom Cab.
G = C4 Cruise-O-Matic.
17 = Ford 9" Rear Axle / 3.25-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
150 net HP @ 3,600 RPM
65 = Oklahoma City OK Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Dec 10, 2014 | 07:26 AM
Argie66's Avatar
Argie66
Trailering
Thanks lot! I was told the original color was blue/white and V8 motor..... thanks for clarifying!
WebRep
Old Dec 10, 2014 | 05:57 PM
SuperSabre's Avatar
SuperSabre
If the information Number Dummy gave you on the warranty plate decode doesn't square with what you are seeing on your truck, there is always the chance that some PO has replaced the driver's door and brought with it an incorrect warranty plate. It happens a lot. These things are 50 years old. Perhaps you should check the VIN on the top of the passenger side frame rail against the door plate information and the VIN on your title to make sure all three read the same.
Old Dec 10, 2014 | 07:11 PM
Argie66's Avatar
Argie66
Trailering
Thanks! I'll check the frame.... the warranty plate does look too new, like if it has been replaced at some point. Is that even possible?
WebRep
Old Dec 10, 2014 | 08:00 PM
SuperSabre's Avatar
SuperSabre
Sure it's possible. The plate can be removed by either drilling out the rivets, or the original rivets can sometimes be reused by punching them "backwards" from inside the door cavity. Reproduction warranty plates are available from Kevin Marti (who does the Mustang reports) and he will emboss them for you if you provide the information. I'm pretty sure he has some safeguards in place to keep just anybody from requesting whatever they want, but I'm not an expert on that. Good luck!
Old Dec 11, 2014 | 09:36 PM
Argie66's Avatar
Argie66
Trailering
Thank you!
WebRep
Troy_Lee
Feb 17, 2018 12:14 PM
Pireaux
Jul 19, 2014 12:08 PM
breedo99
Jan 28, 2014 08:40 PM
Williamkwebn
Jun 28, 2013 11:39 AM
frdavid
Nov 29, 2008 06:51 PM
