F1 '51, steering column to rack and pinion
Old 07-06-2016, 06:22 PM
firedrake's Avatar
firedrake
firedrake is offline
Hi to all, I want to use a tilt steering column on my 51 F1. I am using a mustang II front end with power r&p and am curious what length and manufacturer would be best?
Old 07-07-2016, 07:52 AM
04Z06Vette's Avatar
04Z06Vette
04Z06Vette is offline
I used a 77 cutlass tilt column on my 49. It has key in column, but set up for a floor shifter. it lined up pretty well.
Old 07-07-2016, 10:46 AM
firedrake's Avatar
firedrake
04Z06Vette, Hello, And you were connecting to a r&p? I assume that there are several years that in the '77 range that would fit, and had a column shift?
Old 07-08-2016, 07:40 AM
04Z06Vette's Avatar
04Z06Vette
Yes, I have it going to a stock mustang 2 power rack and pinion. it connects with a couple of borgeson u joints and a length of double d rod. the 77 did not have the column shift which was what I wanted. easier to put in a floor shifter for the automatic that figure out the column linkage. there are probably other years that were similar size. if you want column shift, then you need a different model.
Old 07-08-2016, 12:43 PM
firedrake's Avatar
firedrake
Thanks for the heads-up on that particular column, I guess I'll keep looking.
Old 07-16-2016, 10:11 AM
tip49's Avatar
tip49
tip49 is offline
MII front end with modified "stock" steering wheel
I coupled my R&P with Borgeson u joints and modifed "D" shaft linkage to my stock steering wheel.
My linkage goes through driver side motor mount but operates great.
Tom
Old 07-16-2016, 12:42 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
1975 or so cutlass column, swap meet score.
Measure from the floor to where you want the steering wheel to be, put a wheel in a piece of PCV tubing or something to get an idea of position. Then see how much room you have in the engine compartment to extend in, the shorter the better to allow length for u joints and the DD shaft.
Then with a good idea of length you can hit the swap meets, junkyards, or buy new. I use factory stuff so I try to find columns with either a DD shaft on the end I can cut down or a splined end that I can put a ujoint on.
There are also adapters out there to go from a rag joint style flange to a splined stub.
mustangmike6996
06-15-2015 05:33 AM
tomrflorida
07-13-2013 11:55 AM
52' fordnut
12-10-2012 07:51 PM
56Jeff
08-17-2004 08:25 PM
ABOERNER
09-29-2003 04:34 AM
Quick Reply: F1 '51, steering column to rack and pinion
