About 3months ago the right side canceling arm broke,ok no big deal(also adjusted the rear brakes 2 weeks ago).My neighbor said my right brake light wasn't working,changed out bulb and everything clean and tight.Looked at the brake switch,good there.It's when I start moving the signal lever will the right rear brake come on,either with the key on or off.Signals won't work with key off(like they should) but the brakes do(key on or off). Been like this for a few days after I found out about the light.
It's only when I work the signal lever either way does the right rear brake light come on.Also in the key off position the left brake light will go off and then the right one will work while working the lever,but then I can get both to work. Sound like a new switch,with tilt. Going to pull the wheel off again and have a better look see. Did read about grounds.
Any thoughts? Rock Auto 75$ shipped
79 f250 c6
