brake indicator light
Old Nov 25, 2002 | 08:44 PM
idealtrucks's Avatar
idealtrucks
The little light that is above the emergency brake that glows red and says brake is staying on all the time on my truck. i have the light out of it now but i was just wondering why it burns all the time. Is this a warning light for brake faliure or for an emergency brake on? i have an all new brake system on my truck so there is nothing wrong with the brakes. any ideas??
Old Nov 25, 2002 | 08:49 PM
rebocardo's Avatar
rebocardo
Yes or it means the equalizing valve was not centered correctly after bleeding the brakes.
Old Nov 25, 2002 | 09:02 PM
idealtrucks
how could i fix this or should i just leave the little light out of it??
Old Nov 26, 2002 | 01:03 PM
William's Avatar
William
Loosen a front brake bleeder screw and push the pedal down until the light goes out. Tighten the valve. If that doesn't work loosen a valve on the rear, follow same procedure, when light goes out tighten the bleeder valve. If the equalizing valve still won't center take the switch off at the combination valve and pry it to center. I'd almost bet you do not have rear brakes! just a random thought!
William in Atlanta.
Old Nov 26, 2002 | 09:22 PM
idealtrucks
id say it is the switch stuck because the light stayed on all the time before and after i redone all the brakes.
Old Nov 27, 2002 | 12:42 AM
BB's Avatar
BB
