Stalled.......
Old Jul 12, 2016 | 01:57 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by swmpbgy1
Greetings all.....my 2000 EX 7.3l just stalled.....Any other items I should check?
Originally Posted by ruffneck30
Check the nut on the ipr if is still on. Will cause a a stall.
Thanks for the info........What am I trying to diagnose?
Umm, your stalling issue.
Or are you chasing down other problems you haven't told us about?
Is the nut supposed to be on or off??
Methinks you posted after a few beverages, yes? I'm fairly certain you didn't really mean to ask that.
Stewart
Old Jul 12, 2016 | 02:12 PM
swmpbgy1's Avatar
swmpbgy1
Stewart
Sorry about that.....I guess I really don't understand what I'm looking for. If the nut is gone, do I replace the nut? Buy a new IPR? or what????
What does the nut do?
Swmpbgy1
Old Jul 12, 2016 | 07:54 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
The tin nut holds the IPR together. Without it, or if it is loose, the solenoid will slop around and not control the plunger accurately. If not there, look carefully in the valley as it probably did not go far. It's a flimsy thing so don't over tighten. Drop of thread lock helps. The tin nut is available in the IPR Rebuild Kit.
Old Jul 13, 2016 | 11:30 AM
swmpbgy1's Avatar
swmpbgy1
Thanks!!! Just the info I was looking for.
Swmpbgy1
Old Jul 14, 2016 | 12:58 PM
swmpbgy1's Avatar
swmpbgy1
Checked the IPR this morning....all is good there......the "nut" is on tight.
My CPS will be here today.......
Swmpbgy1
pwstroker69
44
Apr 28, 2018 12:17 PM
'02STROKER
Aug 1, 2017 10:39 AM
deputy
May 3, 2011 01:58 PM
ford350hd
Aug 31, 2005 06:27 AM
dieselstroke
Feb 13, 2005 07:27 PM
