gearing
Old Apr 9, 2012 | 03:37 AM
jkuhane's Avatar
jkuhane
gearing
So I just swapped out my rear diff that had 3.25 to 4.88 with a Detroit locker. The owner s before me tried to run 38" tires with 3.25 gears!! But I'm ready to do the front which is a Dana 44 high pinion. Does anyone know the pinion spline count and axle spline count? My truck is a 1977 Ford f150 4x4. Worst case scenario would be to pull the axle and check before I order, but could anyone save me some time? Thanks
Old Apr 9, 2012 | 09:00 AM
Poison Oil Racing's Avatar
Poison Oil Racing
I would probably be just as easy to pull a front axle and count them now since you can't drive the truck around with such radically different gears in it.
Then you will know for sure what you are ordering.
Old Apr 9, 2012 | 10:10 AM
Stinky7-11's Avatar
Stinky7-11
Sure he can drive it all he wants just be safe and pull the front driveshaft, not really sure of t-case and he may have to pull the DS with a full time t-case(np203).
jkuhane, Get the B.O.M.# off the front of the passenger side axle tube, it will look like this ( 2 24 6 A4 603781 8 ) then search it on the web, post it here for more help also Call Randys ring and pinion at 1-866-631-0196 if you still need help. Something for toilet time, Dana 44 Solid Front Axle: Part 1 Reverse Spiral Housing.
Old Apr 9, 2012 | 01:33 PM
jkuhane's Avatar
jkuhane
Thanks for the reply guys. The number on the axle read 6 20 7 b5 and 610024 1r
Ill try and research it on the web
Old Apr 9, 2012 | 07:49 PM
HIO Silver's Avatar
HIO Silver
Here you go.. this applications reference catalog is buried deep in the Spicer/Dana site:
http://www2.dana.com/pdf/X510-8DSD.pdf
on this page: Dana Holding Corporation The Expert Librarian - Information for driveshafts, u-joints, axles, heavy axles, light axles, Drivelines
BOOKMARK FOR FUTURE REFERENCE!!!!
Here is the cover:
EDIT: There is a separate reference catalog for 79 and newer Fords.
amish77
Mar 23, 2019 05:44 AM
Kyle 4X4 4life
Jan 28, 2011 08:38 AM
trebor_9513
Aug 20, 2008 12:42 PM
armikk
Offroad & 4x4
Oct 20, 2005 04:09 PM
warrencowboy05
Offroad & 4x4
Feb 25, 2005 03:11 PM
