Diffrent Oil cooler solutions
Old Jul 3, 2016 | 01:45 PM
BLADE35's Avatar
BLADE35
Iv seen all the BPD options but I know I saw others awhile back
it needs to be in a kit Ideally for time purpose but anythings worth a look
wish I had time to do the DIY air to oil but theres a lot of time trying to fabricate something like this
Old Jul 3, 2016 | 01:48 PM
BLADE35's Avatar
BLADE35
Forgot to ask but How was the kit to install any issue with assembly or fitment
anyone running IPR stuff?
I like the idea of 100% coolant filtration before it enters the oil cooler
Old Jul 3, 2016 | 02:26 PM
wedge542's Avatar
wedge542
Have you seen the delta kit from absolute perf, read good things so far about it.
Old Jul 3, 2016 | 02:28 PM
BLADE35's Avatar
BLADE35
I haven't but would love to check it out do you have a Link
Old Jul 3, 2016 | 02:31 PM
wedge542's Avatar
wedge542
absolute performance
Old Jul 3, 2016 | 02:33 PM
wedge542's Avatar
wedge542
AP 6.0 Delta kit
Old Jul 3, 2016 | 03:53 PM
BLADE35's Avatar
BLADE35
what is it
to me it just looked like a line that reroutes the coolant from the cooler exit port over to the heater return line
Old Jul 3, 2016 | 05:42 PM
npccpartsman's Avatar
npccpartsman
No way that would fix a plugged oil cooler.
Old Jul 3, 2016 | 06:18 PM
BLADE35's Avatar
BLADE35
You took the words out my mouth
Tim
It was 175
I don't know what it would be good for
That thing don't even have enough parts to make the truck operational cause coolant would flow out the intake
Old Jul 3, 2016 | 06:33 PM
BLADE35's Avatar
BLADE35
Now the BPD relocate kit could be modified to do 100% filter of any coolant going to oil cooler
The filter might have to be an IPR high flow coolant filter kit
Unless a regular filter could allow enough flow
Maybe it just needs air to oil at that rate
I'm not sure how to fix this thing guys I feel stuck
Old Jul 3, 2016 | 06:53 PM
wedge542's Avatar
wedge542
sorry benny, was hoping that might help if you wanted to backflush a fairly new oil cooler before it was a old solid plugged unit with no help, it seemed to help a few after they backflushed and used that kit afterwards.
Old Jul 3, 2016 | 08:14 PM
BLADE35's Avatar
BLADE35
That must be it cause idk what else it would be good for
Old Jul 3, 2016 | 08:47 PM
wedge542's Avatar
wedge542
If you can would you post picts of whats flushing from your system.
Old Jul 3, 2016 | 10:18 PM
jetjockey99's Avatar
jetjockey99
That kit is used with a new or properly functioning oil cooler it just routes the coolant flow directly to the hose under the degas tank, bypassing any flow through the intake manifold. It requires the EGR be removed and the manifold plugged for both exhaust flow and coolant flow. I did the same thing on mine years ago with a $10.00 fitting and a modified cover on cooler outlet running a -12 hose directly to the degas, this kit just makes it easier.
Old Jul 3, 2016 | 10:35 PM
wedge542's Avatar
wedge542
Did mine to but this kit looks good,my fitting was about 4 bucks and some hose and clamps- but if he can pull the little cover off and put a hose on the return side to backflush the cooler then add that kit may be ok,im sure it being a new cooler its not baked in it yet like a 1-2 yr old cooler gets, maybe pour some mean green in the coolers return side let sit then backflush, but if 16-1700 laying around get that other option and forget it. Here is some reading about this kit from its founder from the very start-http://powerstrokearmy.com/forums/showthread.php?t=40084
