Pikes Peak
Old Jul 3, 2016 | 12:14 AM
rwelli1001's Avatar
rwelli1001
Pikes Peak
Desending from summit of pikes peak today. My 94 7.3 Turbo IDI manual 5 speed 4x4 started making an abnormal clicking noise. Coming from passenger or odd side of the engine.
Want to tow or transport truck back home. For repairs.
Any recommended company for this?
Notes 232,000 miles on the truck. Origional engine.
Never been opened up.
Just drove from Las Vegas Nv. To Colorado Springs Colorado (830 miles) avg 16 mpg with 4/10 gearing. Driving 65 to 70 mph. Tarp over the bed.
Old Jul 3, 2016 | 01:03 AM
Macrobb's Avatar
Macrobb
Does it make the noise when decelerating, or only under power?
If it's only under power, it's probably just an injector and you are probably OK.
Got any videos?
Old Jul 3, 2016 | 08:29 AM
rwelli1001's Avatar
rwelli1001
Have pics no video.
Have not posted any pics yet and not sure if I am able to yet.
Noise there all the time and louder as I speed up the engine.
Engine not running any ruffer than before. last compression check 2 summers ago, #'s 3&4 were low at 325. The rest were 425. I had my injection pump rebuilt at that time and I installed a new set of Stanadyne Injectors also.
Before leaving on this trip. I put a new water pump, hoses, coolant and distilled water, with 2 bottles of Diesel coolant additive from one of my local Ford dealers.
On the hill I checked the radiator, (an inch low from cap) and over flow bottle. The bottle did not have any just green coolant left in it but had a small amount of a black liquid. (Maybe quater cup) Coolant in radiator was a brownish green color and did not look like what was in the overflow bottle.
Have to get ready for church now.
Old Jul 3, 2016 | 09:46 AM
Macrobb's Avatar
Macrobb
I wonder... is the sound something like this?
That turned out to be a (major) exhaust leak.
Also, note that my truck has a turbo too.
Old Jul 3, 2016 | 11:08 AM
rwelli1001's Avatar
rwelli1001
No I replaced the clamp on the turbo discharge pipe to exhaust pipe before leaving. It had been missing for some time. Thought is was a different location for my exhaust leak and was going to fix it when I get a clutch. But when a muffler shop showed me the leak I fixed it the next day.
New sound is not the same sound. Sound is originating from passenger side towards front of the engine. About Cyclinder # 3 location.
Old Jul 3, 2016 | 11:09 AM
rwelli1001's Avatar
rwelli1001
I do have a video. At the peak.
Old Jul 3, 2016 | 11:38 AM
rwelli1001's Avatar
rwelli1001
Just went out to reposition truck on the street.
From inside the cab
Sounds like a lifter is not working properly.
Old Jul 3, 2016 | 10:23 PM
Macrobb's Avatar
Macrobb
From inside the cab
What's it doing? Would an impromptu oil change perhaps solve it?
Old Jul 4, 2016 | 06:34 PM
rwelli1001's Avatar
rwelli1001
Maybe. Oil changed day before leaving Vegas. Usual place had a two hour wait so went some where else. Have been using Rotella but this change used Delo. About a 840 highway miles and a weeks worth of city driving. Used and leaked about a quart and a half of oil on the road. Was only a quart low when I got to Colorado Springs.
Old Jul 6, 2016 | 12:34 PM
rwelli1001's Avatar
rwelli1001
Truck is on its way home Via Albuquerque NM. Should be here tomorrow night.
Driver of the transport lives Here in the Vegas Valley area. imagine that.
Old Aug 1, 2016 | 10:04 PM
rwelli1001's Avatar
rwelli1001
Pikes Peak summit 7-2-16
http://i1380.photobucket.com/albums/...&1470106534496
Video of Peak
IMG_1174_zpssittavko.mp4 Video by rwelli1001 | Photobucket
Another shot on the peak.
Getting off the transport truck. You can here the clicking noise from the engine.
IMG_1294_zpsxgcys6zz.mp4 Video by rwelli1001 | Photobucket
If the links do not work for you please let me know.
Thanks for any more ideas about the clicking noise.
Old Aug 2, 2016 | 09:36 AM
Macrobb's Avatar
Macrobb
Pull the valve covers. Check for anything loose, not moving as it should.
Oh; check the exhaust. Is there any pulsing at idle if you put a piece of paper in the exhaust stream?
If you have a good set of glow plugs, you can also let it idle, and check resistance from each glow plug(unplugged from the harness) to ground; this will effectively tell you the cylinder balance - a lower resistance glow plug means a hotter cylinder, a higher resistance ones means a cooler cylinder.
Look for anything far different from the rest.
Old Aug 2, 2016 | 08:08 PM
rwelli1001's Avatar
rwelli1001
@ Macrobb.
Will do the glow plug test first before pulling the Valve covers.
I like this test. This would be a great addition to put in the glow plug sticky.
Will not be able to work on the truck for another week or so. But have finally got my back up transportation up and running. No more rentals hopefully.
Want to set up a large swamp cooler to blow around in the garage and under the hood while working on the truck. Have a cover for shade in the drive way but still very warm outside this time of year.
Have to work in driveway. Truck is too long for the garage. Even with front bumper on back wall, rear bumper is still outside the role up door.
Pictures ok?
And Thanks for your time and advise.
Old Aug 3, 2016 | 10:27 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Heat increases resistance ...
-Enjoy
fh : )_~
Old Aug 6, 2016 | 04:26 AM
Leroy Unlisted's Avatar
Leroy Unlisted
It does sound like a collapsed lifter ..
I've fixed sticky lifters before .. drain a few quarts of oil and top it off with a brew of marvel mistery oil , atf , and straight diesel fuel .. the diesel thins it so the mmo and atf can penetrate the oil passages in the lifters ..
Warm it up and to and take it on the freeway and run it a good rip at high rpms to free em'
Change oil once they operate normally and quiet again ..
I do it whenever i hear one getting stiff or sticky .. i only have had to do it once in my truck .. it was just starting and cleaned em' all right up ..
ol timers used to drain oil at oil changes fill with diesel .. run a minute. . Drain and add fresh oil .. that'll clean em' out too .
EconolineFan
22
Jun 25, 2019 04:18 PM
lauraj
Aug 3, 2015 02:20 PM
9228.bobcat
6.4L Power Stroke Diesel
13
Mar 20, 2013 10:40 AM
RedDirtLandscaping
Jun 27, 2011 09:23 PM
truestory
Mar 15, 2005 01:26 AM
