Sponsored by: Auxito
If I wanted switch engines....
Old Aug 17, 2003 | 06:25 PM
AegisSailor's Avatar
AegisSailor
Hi folks,
I just got to thinking today about how to spend my upcomming bonus. If I wanted to swap my 4.2L with a 5.4L, would it be a direct replacement? I can see no reason why it wouldn't fit, the trucks are all the same right?
I imagine that the computer would have to be swapped too, but I can't really think of anything else that would have to change. My manual tranny would bolt right up wouldn't it?
Anybody know a reliable supplier of remanufactured engines? I thought there was an old thread here about different engine suppliers but I can't find it.
It's all theoretical at this point, but I'd appreciate your opinions.
Roger
Old Aug 18, 2003 | 01:11 PM
JeremyH's Avatar
JeremyH
Keep in mind that these engines might differ in weight and that might affect your suspension.
Old Aug 18, 2003 | 02:38 PM
Racerguy's Avatar
Racerguy
If you had a donor truck to take all the parts off you would be ok. The transmission is different, motor mounts, exhaust, all brackets on the engine, p/s pump. alternator etc etc etc are all different.
Old Aug 19, 2003 | 09:02 AM
1991fseries's Avatar
1991fseries
the transmission should be the same as long has it's an auto else you'd need to get an auto. the other thing is while it won't make a differance in the swap the 5.4 came with an 9.25 rear and the 4.2 and 4.6 came with the 8.8 rear end
Old Aug 19, 2003 | 09:42 AM
AegisSailor
Well screw that, I'm not driving an auto!
Old Jun 3, 2010 | 02:33 AM
citybean's Avatar
citybean
will it swap or be a nightmare 4.2l to 5.4l triton
hello all i have a 2000 ford f150 with 300,000 miles on factory motor my 8.8 rearend went bad so i replaced it with a 9.00 and rebuilt the auto tranny . i ran across a 2001 5.4l triton motor with everything wiring harness,a/c,ps and alt.with 30,000 miles on it .i was told it would bolt up to my auto trans all i would need is computer and exhaust , and motor mounts is there anything else im missing would like everyone input thanks
Old Jun 3, 2010 | 10:47 AM
Tex1986's Avatar
Tex1986
Do a search on this forum. There's a 6 page thread laying around here somewhere that covers this issue. You have to swap EVERYTHING out. Harnesses, ECU, and w/that PATS, mounts, and I think I heard you need a tune as well. It's not an easy job and is something for fun as the gains are minimal.
Old Jul 30, 2010 | 11:38 PM
fordor204's Avatar
fordor204
I have a 98 F150 5.4 with a knock and am considering replacing it with a 5.4 out of a 2002 F350. IS this feasible and what is involved?
Old Sep 7, 2010 | 11:05 PM
fastfords94's Avatar
fastfords94
i have a 97 4.2 and the motor needs replaced i was wondering what all engines will bolt up without changing alot of stuff and costing me a fortune it is a 5 speed and when i bought this truck it was fine then a couple months later it started using oil like crazy if anyone has any sugestions please let me know thanks
Old Sep 8, 2010 | 12:10 AM
Hybris's Avatar
Hybris
I would think it possible but it would be best to ask in the Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums section as they would likely know more about what is needed.
You're better off fixing the 4.2 then trying to swap in a V8 ( Although a 4.6 might work) unless you can get a cheap donor truck that has everything (block, mounts, maybe the tranny, etc...) you need for the swap.
Marteney
Jan 5, 2014 01:33 PM
whitestang161
Dec 6, 2009 09:30 PM
dgeist
Jan 31, 2005 03:47 PM
ga302p
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 19, 2005 09:02 PM
