New Ex owner
Old Jul 1, 2016 | 04:53 PM
Axiss's Avatar
Axiss
When I try to start it, the engine turns over like it's going to crank, but it doesn't. I usually have to try this a few times before it actually fires up. There's no clicking noise or dragging like with a battery/starter issue, it just doesn't want to start. Doesn't happen every time, but it's never happened on a cold start, it's always when I've driven it a ways, kill it, then get back in it to start it again.
Old Jul 2, 2016 | 02:08 AM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
To me "crank" means the starter has engaged the flex plate and is rotating the engine.
"Turn over" to me means exactly the same thing.
Crank and turn over are interchangeable words used to describe the exact same thing.
"Fired up" means it has started. Cranking or turning the engine over is what you do in the process of starting the engine.
If it doesn't crank or doesn't turn over the starter has not engaged the the flex plate.
I am still fuzzy on exactly what you mean but I am guessing that the starter is engaging and the engine is rotating but not actually starting. See my above post for likely culprits and the remedy.
Old Jul 2, 2016 | 05:13 AM
Tedster9's Avatar
Tedster9
"My car won't crank", means engine won't start down south, and causes confusion everywhere else because to most people engine cranking = engine turning over.
Old Jul 2, 2016 | 06:48 AM
Axiss's Avatar
Axiss
I forget sometimes that there's a language barrier that exists between us in the south and our brothers in the north, thanks for helping Tedster.
So, to help clarify, and not to flog a dead horse but I'm afraid of getting stranded somewhere so it needs to be fixed. When I turn the key, the engine rotates and the starter engages the flywheel, but the engine does not actually start running. I have to do this a couple of times before it actually busts off (a term my dad used often) and starts running. As I said before, batteries aren't dragging like they're bad and the starter is doing its job, it just doesn't want to crank. I mean fire up. Or whatever.
Old Jul 2, 2016 | 08:11 AM
Tedster9's Avatar
Tedster9
"Kick the tars an' light the fars"?
Sorry.
Old Jul 2, 2016 | 12:11 PM
pirate4x4_camo
FTE Remembers
Did you change the oil like I suggested ?
Old Jul 2, 2016 | 12:24 PM
fordboy2's Avatar
fordboy2
Sounds like it's not seeing the pressure to fire the injectors until you crank it long enough to rebuild pressure. As suggested start by changing the oil.
Old Jul 4, 2016 | 09:16 AM
Axiss's Avatar
Axiss
Oil, oil filter, and fuel filter were changed this past Friday.
mrjustice1324
27
Jul 29, 2019 09:09 AM
Jmmason2626
May 26, 2018 01:37 AM
jwhopson
May 26, 2012 02:09 PM
GKANSA
Electrical Systems/Wiring
13
Feb 2, 2011 09:07 AM
7.3 Rocket
74
Jul 23, 2009 03:18 PM
