Vaper locking
Old Jun 28, 2016 | 02:58 PM
RayW.'s Avatar
RayW.
Vaper locking
I have a 85 ranger 4x4 2.8 and it is vaper locking any ways to help to stop it
Old Jun 29, 2016 | 08:55 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I have heard of a lot of bandaid solutions like a wooden close pin on the fuel line, but that did not work every time. You could bypass the fuel pump and install a low pressure electric pump.
Old Jun 29, 2016 | 09:11 AM
RayW.'s Avatar
RayW.
Vaper locking
Thanks ranger pat
Old Jul 2, 2016 | 07:27 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Lets think about this some more.
Has the problem come about slowly over time, or suddenly after some event? Like after a repair, or a change in operating condition, or a change in fuel supply, like after filling up in a out of the way, low volume station, or even your regular station, as they could have gotten a load of out of spec vapor pressure summer fuel, or the out of the way station is still pumping low vapor pressure winter fuel, that's known to cause hot temp vapor lock.
Around here we hear of interstate folks from up north, traveling down south with a load of winter fuel, have the engine shut down while running hot in the surrounding mountains.
You could try ducting cooler fresh outside air at the problem under hood area & see how it goes.
EDIT: I believe you have a return type fuel delivery system that re-routs unused fuel from the engine compartment back to the fuel tank & that returning fuel has picked up engine heat & transferring it to the fuel tank, so if the tank is low on fuel, it'll get hot faster than a full tank & that can induce vapor lock, especially if you still have low vapor pressure winter fuel in the tank.
More thoughts for pondering, let us know what you find.
Larry NCKS
6.4L Power Stroke Diesel
Jun 8, 2015 09:16 AM
Bill the plumma
Nov 3, 2014 07:42 AM
joesluckyseven
15
Jul 27, 2014 05:51 PM
cajunsuperduty
Jun 29, 2013 10:12 PM
MisterCMK
Mar 20, 2007 08:06 AM
