When low on fuel...
Old Mar 10, 2007 | 11:22 PM
MisterCMK's Avatar
MisterCMK
When low on fuel...
When your truck is low on fuel does it stutter or stumble when taking off? Ours seems to do that when it gets down towards E and I Was just wondering if anyone else has the same thing happen to them.
Old Mar 10, 2007 | 11:35 PM
westtntrucker's Avatar
westtntrucker
Personally I do not like to let my vehicles get below a 1\4 tank for several reasons,
1; most of your intank fuel pumps are fuel cooled, when ther is no fuel around them they tend to get warmer and wear out faster.
2; on diesels, if the fuel gets too low you will suck air and if you have ever tried to prime a diesel........................on gas motors they will suck air and stumble as you have mentioned.
3; what if........... some emergency arises where there is no power to the pumps in your area, only 50 miles away. Do you have enough to get there.
I like to hope for the best, but always prepare for the worst!
Old Mar 11, 2007 | 11:32 AM
amm888's Avatar
amm888
my expys have gotten quite low several times and nothing like that has every happened (stuttering, stumbling).
Old Mar 11, 2007 | 11:07 PM
marinazaz's Avatar
marinazaz
My 98 xp does the same thing when low on fuel, around a qtr tank. Ive been low on fuel and parked on a downgrade only to find the truck wont start as if out of fuel completely\ I guess the pickup is in the rear of the tank .. I have heard of the same issue with the fuel pump overheating and quitting prematurely somewhere, probably on one of these forums. Lately i just keep the tanks above a qtr tank and i havent had the stuttering and misfiring i used to have. I wonder if I should change the fuel pump, its probably pretty expensive though and probably better if i just let it go out completely before i change it.
Old Mar 11, 2007 | 11:53 PM
MisterCMK's Avatar
MisterCMK
This truck has done it since it was new. I wouldn't worry about the pump.
Old Mar 12, 2007 | 05:19 PM
FTE Herman's Avatar
FTE Herman
There was a TSB on this when making a left turn and the fuel was low. I posted this once or twice before, but have no knowledge of a solution.
Old Mar 12, 2007 | 06:09 PM
pitrow's Avatar
pitrow
I just want to chime in and dispel that myth. While it's true that most in-tank fuel pumps are cooled by the fuel, it's the fuel flowing THROUGH them that keeps them cool... not the fuel that's around it.
Now... letting the tank get low enough that the pump sucks air IS a quick way to destroy the pump, so you're probably right about not letting the tank get too low, but not because the fuel pump is exposed.
Old Mar 12, 2007 | 09:18 PM
aagitch's Avatar
aagitch
i've let the fuel low light come on a few times and no stumble problem. was going to suggest fuel filter but since its done it from new?
Old Mar 12, 2007 | 09:38 PM
MisterCMK's Avatar
MisterCMK
Nah, the fuel filter was changed less than 5k ago. I would really like to see that TSB...
Old Mar 14, 2007 | 12:36 AM
VTEXP's Avatar
VTEXP
I've driven a couple miles with the computer saying 0 miles to go...never had that problem on my 99.
Old Mar 14, 2007 | 10:16 AM
shandell's Avatar
shandell
I was having that symptom,among others, of course as anyone here you read my post on "starting issues/2001 EXP", it did turn out to be the fuel pump. I would not recommend if it is the fuel pump, and only if it is the fuel pump, on letting it go out first before replacement, cause to be stuck in the middle of nowhere is not a picnic. Any qualified mechanic or yourself for that matter ,can check the fuel pump and see if it is working properly. Mine I guess were not qualified. Good Luck!
Old Mar 14, 2007 | 09:11 PM
marinazaz's Avatar
marinazaz
What is the simplest method to check proper operation of the fuel pump. Pressure in the fuel manifold?
Old Mar 15, 2007 | 08:39 AM
shandell's Avatar
shandell
If you can locate the post of mine 2001 Exp/Starting issues under search, a really nice person posted in detail how to check the fuel pump pressure. I tried to copy and paste it here but it did not work for me. Sorry. Maybe someone else has the know how to do it if they see this post. I will try it for you again.
Old Mar 15, 2007 | 08:45 AM
shandell's Avatar
shandell
2001 Ford Expedition/ starting issues / is back about three pages in our threads, again I tried to put it in. to know avail, sorry.
Old Mar 20, 2007 | 08:06 AM
gibsonj's Avatar
gibsonj
Shandell,
The 2K Expy 5.4 has a schrader valve on the passenger side fuel rail. Hook up a fuel pressure gauge to this port to check fuel pump pressure. When you turn key to "on", the pump energizes and you should get a pressure reading at the rail.
erikkloss
Jan 16, 2017 01:54 PM
jdhudall
2009 - 2014 F150
Jan 11, 2017 11:28 PM
mmenzies
Sep 28, 2016 05:04 AM
Bumper1475
Mar 5, 2014 06:15 AM
gibbsdakota
Apr 3, 2012 08:05 PM
