Starting issues
Old Jun 28, 2016 | 09:31 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
That is the Glow Plugs cycling and it is normal.
The Glow Plugs should come on for about 10 seconds, then go off for about 5 seconds then start cycling to provide after start heat assistance.
Did you test them following the procedure in post #8?
-Enjoy
fh : )_~
Old Jun 28, 2016 | 09:48 PM
nut_wrinkle's Avatar
nut_wrinkle
Banned
Step 8? umm, I am not sure which step that is. I did not do the part that you said not to do unless I knew what it was.
Old Jun 28, 2016 | 10:11 PM
madpogue's Avatar
madpogue
Edit - disregard - I didn't see the intervening posts....
Old Jun 28, 2016 | 10:33 PM
Festus Hagen
Methanoholic
That was Post #8.
Where I described how to Test Light Test the glow plugs ...
That's good!
And just so we are clear, the starting procedure is
  • Turn Key on ... Wait for the WTS (Wait To Start) light to go off
  • Turn key to start for 20 seconds (Unless it starts)
  • Turn key off
Wait 2 minutes
  • Turn key off
You may have to repeat this to get the air out, Batteries will run down, They need to be kept up.
Every time you leave it set more then a few hours it will drain the fuel back down and you will have to start all over again ... You've got to stick with it with good batteries until it starts.
It should run if it was parked running ... Why was it parked?
How much fuel is in the tanks, at least half full?
-Enjoy
fh : )_~
Old Jun 29, 2016 | 12:22 AM
speedwrench72's Avatar
speedwrench72
Know one has told him to hold the throttle peddle down all the way for all starting attempts, FYI,,,never change a fuel filter on a IDI when engine is not fully warm....HOLD THE PEDDLE ON FULL.
Jomama182
1978 - 1996 Big Bronco
13
Jan 14, 2023 12:20 PM
jpalladino
Apr 12, 2014 09:20 AM
jorge.s
Jan 14, 2012 07:33 PM
custom_nirvana
43
May 24, 2008 04:33 PM
CaseyJones
18
Mar 21, 2006 01:24 PM
