Hard to start.
Old Oct 16, 2011 | 07:00 PM
jorge.s's Avatar
jorge.s
Hard to start.
94 F150 4.9 EFI : Use to start at the first turn now it take about twenty to thirty turns to start.
New plugs & wires,distributor cap & rotor,fuel pumps. When idles it smoke a little (white smoke).Any ideas?
Old Oct 16, 2011 | 07:12 PM
bashby's Avatar
bashby
WHen you turn the key on, the fuel pump should turn on for a few seconds. It may not be turning on until you start cranking, then take a couple seconds to build pressure. You should be able to turn the key on and hear the pump come on for a couple seconds. You may need to have someone operate the key while you listen to the fuel tank area.
Old Oct 16, 2011 | 07:26 PM
jorge.s's Avatar
jorge.s
Two new fuel pumps ;Yes, I can hear them running when I turn the key.
Old Jan 14, 2012 | 07:33 PM
mojo79's Avatar
mojo79
Ok, so what did you find as the problem?
this is a give and take forum...
racin
1997 - 2003 F150
Jan 14, 2016 10:22 PM
Idaho Mtn Man
Sep 22, 2012 09:35 PM
rudy11hoops
2004 - 2008 F150
Oct 14, 2008 09:12 PM
AnOldDog
1997 - 2003 F150
Jan 17, 2007 12:58 PM
iwanarace
Nov 10, 2006 08:32 PM
