06 ford explorer
Old Jun 27, 2016 | 07:36 AM
TaraLyne1010's Avatar
TaraLyne1010
06 ford explorer
I have a 2006 ford explorer 6 cylinder. It has been giving me trouble. It started running rough after a trip to TN. Took it and had thrm put it in machine. They said EGR valve. So i changed it. Now it running worse. Stalling or trying to stall. Take it back they say it could be a couple things. The o2 sensore or a hose clog. Im at my wits end and cant keep putting moneykeepthis truck for them to keep guessing.
Old Jun 28, 2016 | 01:00 PM
shorod's Avatar
shorod
There are virtually no codes that state exactly what part is bad, only which system is reporting out of specification values to give the technician a place to start with their diagnostics. If you go to a parts store and they say, "You need a new EGR valve" you should be hesitant and instead ask for the exact code number to do further diagnosis.
Did you happen to get the exact code numbers, and if so, please provide them.
-Rod
Old Jun 28, 2016 | 01:38 PM
TaraLyne1010
For explorer
The code is pulling up an egr valve leak, a couple o2 sensors. I dont know how old the battery is.
Old Jun 28, 2016 | 05:36 PM
shorod's Avatar
shorod
There are several codes related to the EGR valve and even more related to the multiple oxygen sensors on the vehicle. Having the specific code numbers might really help with the diagnosis.
-Rod
Misky6.0
Jun 6, 2011 11:15 AM
j94tbird
Apr 7, 2005 01:37 AM
mrmcdb2005
1983 - 2012 Ranger & B-Series
13
Sep 15, 2004 09:04 PM
JTD1972
May 23, 2004 12:05 AM
robask
Oct 24, 2001 11:20 PM
