egr valve
Old Apr 20, 2004 | 07:21 PM
mrmcdb2005's Avatar
mrmcdb2005
egr valve
will a egr valve cause my teruck run to lean thanks
Old Apr 20, 2004 | 08:24 PM
Rockledge's Avatar
Rockledge
Yes, a lean condition can be related to a bad EGR. But it could be caused by a lot of thiungs.
What year/engine are you talking about? Have you checked for codes?
Old Apr 21, 2004 | 08:06 PM
mrmcdb2005's Avatar
mrmcdb2005
i have a 99 ranger with a 3.0 flex fuel. the codes are p0172 a.d p0174 if you can help or give me any ideas please do thanks
Old Apr 21, 2004 | 08:16 PM
jt-stl's Avatar
jt-stl
I received the p0174 code when my heated o2 sensor was bad. I don't know specifically being coupled with the other code what that's symptomatic of, but it could definitely be suspect.
Old Apr 21, 2004 | 09:33 PM
Rockledge's Avatar
Rockledge
P0172 = System Rich, Bank 1 (Passenger's side of engine)
P0174 = System Lean, Bank 2 (Driver's side)
Seeing those codes together is somewhat of an anomaly, at least to me. It means that one side of your engine (Bank 1) isn't getting enough air and/or is getting too much fuel. Yet the exact opposite is happening on the other side of your engine.
One guess I can offer is that maybe your MAF is malfunctioning, sending a signal that's all over the place to the PCM, resulting in the PCM telling the fuel injectors to fire at inappropriate times. Another thought is maybe your fuel pressure regulator is out of whack.
Are you experiencing any driveability problems? Hesitation, hard starts, bad gas mileage, etc?
Old Apr 22, 2004 | 05:02 PM
mrmcdb2005's Avatar
mrmcdb2005
hard starts and hesitation and it was p0171 anf p0174 both to lean. i done checked for vaccum leaks do not have any. the truck has 97,000 on it and ore the origanal o2 sensors should i change them.
Old Apr 22, 2004 | 07:13 PM
Rockledge's Avatar
Rockledge
Both sides lean at least makes more sense.
Could still be related to fuel delivery and/or fuel pressure. When's the last time you changed thefuel filter? How about fuel injector cleaner, do you ever use it?
Old Apr 22, 2004 | 07:26 PM
mrmcdb2005's Avatar
mrmcdb2005
yes i have used a lot of injestor cleaner but the motor in the truck is not the orginal motor i heard sometimes the ijectors after setting a while will gel up and can not be cleaned is that true. it also hesitates at low and high rpm
Old Apr 26, 2004 | 04:33 PM
mrmcdb2005's Avatar
mrmcdb2005
fixed the problem
thought i would tell you guys it was bad injectors causing all the trouble. thank for all the help.
Old Aug 31, 2004 | 09:32 AM
JJs Ranger's Avatar
JJs Ranger
I previously posted regarding my 99 3.0 hesitating and idling rough only while the ac runs. If I turn the ac off it runs fine. The ac blows ice cold so charging doesn't appear necessary. I have replaced spark plugs, air filter, cleaned MAF and throttle body, replaced IAC with no results. Guys have suggested plug wires or vacuum leaks, but that wouldn't appear to be the case since it only happens with the ac on? Am I correct in my thinking?
I'm close to taking it to the stealership and dish out some cash. Any final thoughts from the techies out there? JJ
Old Sep 1, 2004 | 10:37 AM
cwtravis's Avatar
cwtravis
Hi JJ,
Are there any trouble codes?
Have you checked the throttle position sensor?
Old Sep 1, 2004 | 11:02 AM
Rockledge's Avatar
Rockledge
The PCM is supposed to kick up the idle a little bit when the A/C is engaged in order to accomodate the additional load. This increase is noticeable, particularly when you are looking for it. Maybe something is breaking down between the PCM and the Idle Air Control (IAC) valve. Does your idle increase like this? How is your idle otherwise?
Old Sep 1, 2004 | 04:30 PM
JJs Ranger's Avatar
JJs Ranger
No codes and I have replaced the IAC but not the TPS. I'm suspicious of the TPS since it only does it when the AC is on. JJ
Old Sep 15, 2004 | 09:04 PM
JJs Ranger's Avatar
JJs Ranger
Absent any suggestions I guess it is time to visit the stealership. No codes, I've replaced about everything, wish me luck!
patrickke
Feb 25, 2010 01:47 PM
charschutt
New Member Introductions
Aug 7, 2009 09:53 AM
dantsg
1997 - 2003 F150
Apr 26, 2009 04:59 PM
JCastellaw
Jan 16, 2004 11:35 AM
mathelm
Jan 14, 2003 04:07 PM
