Draining Coolant from the block
Old Jun 25, 2016 | 02:16 PM
Eric Kropp's Avatar
Eric Kropp
So I am changing all the goods on my cooling system. Started out as a water pump change...............but you know! I flushed the system real good with Prestone two stage flush. Recored the radiator, got a new OEM stat, new pump, new hoses etc. I would like to know how to get the rest of the water out of the block so I can fill it with fresh distilled water & coolant. I pulled the block heater to change it, so my water level is down that far.
Thanks!
V465
Old Jun 25, 2016 | 03:37 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
If you look at the image of this block you will see the Coolant Drains, there is one on each side.
EDIT:
PC Correction ... Changed Water to Coolant!
-Enjoy
fh : )_~
Old Jun 25, 2016 | 06:10 PM
genscripter's Avatar
genscripter
WHile you got the plugs out, go on McMaster Carr and buy some valves that thread in. Lots of guys run pet***** in their coolant ports, but i used them and they were more trouble than they are worth. run these valves instead. just connect a foot-long section of hose to the end, flip the switch, and the coolant drains out into your collection basin. easy.
Macmathews
Jul 18, 2016 02:20 PM
jreilly57
20
Jan 17, 2015 07:31 AM
jajones1988
Apr 22, 2014 11:51 AM
jp45601
Aug 5, 2012 10:49 AM
barbershop
15
Jul 3, 2007 05:52 PM
