Thread sizes, oil pressure & water temp
Old 06-23-2016, 08:39 AM
dtgl90vt's Avatar
dtgl90vt
dtgl90vt is offline
Hey,
So my Speedhut gauges are supposed to arrive today; oil pressure & temp, water temp, fuel pressure, boost, and EGT.
I already know where fuel pressure is going. I am going to mount the EGT at the back of drivers side manifold.
Water temp is going to get tee'd from the existing water temp sender, but I don't remember what that thread size is, can anyone remember?
The oil pressure and oil temp, I'm not quite sure where I want to mount, I know I am going to have to adjust when I install the turbo, so maybe there is a place where I can install that will be out of the way. Also does anyone know the thread size for the oil ports?
Thanks Again,
Devin
Old 06-23-2016, 03:34 PM
tecgod13's Avatar
tecgod13
tecgod13 is offline
You don't want to tee in temp gauges. A tee doesn't let the sender get the flow of the fluid. Pressure gauges are fine to tee in as the pressure is the same everywhere.
You can remove the stock coolant temp sender to install the aftermarket one, which will render the stock gauge useless, but may still retain the idiot light if it overheats, I think that depends on which sender you remove (there are two I believe, maybe 3 if you could the cold start circuitry)
Another option is to install it somewhere else. I put one further back on the driverside head. There is a port there with a square headed plug near the exhaust manifold. I believe its 1/2" pipe thread. It was a pain in the *** to get the plug out as I didn't have a square socket of the right size. Also it seems that either the temperature there reads high, or maybe the exhaust manifold being so close is elevating the temp it reports.
There are oil ports by the oil filter in the rear of the engine block. I want to say its small square plugs near the back of the block. The ATS aftermarket turbo gets its oil feed from that location.
Old 06-23-2016, 04:26 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Coolant temp is 1/2 NPT. And 2nd you don't want to T it, just use one of the other ports.
I believe the oil is 1/8 NPT, but I'm not positive now.
Old 06-23-2016, 04:31 PM
wtroger's Avatar
wtroger
wtroger is offline
Oil pressure is 1/4 npt. This a diesel so there is plug on each head that the water temp can go into.
Old 06-23-2016, 04:34 PM
Chevy_Eater
Old 06-23-2016, 04:37 PM
Chevy_Eater
Thanks, my remembery wasn't working on the oil, been a while.
That's true, in fact each head has two coolant ports and only one of the four is in use (over-temp light).
Old 06-23-2016, 04:39 PM
bashby's Avatar
bashby
bashby is offline
I looked at an engine I had on a stand and it looks like the op sensor is bigger than 1/4" npt, I think 3/8. It has an adapter that screws into the block with what looks like 1/8" npt. It didnt look like there was enough room to install a t. There wasnt room to screw one on from what it looked like.
Old 06-23-2016, 04:40 PM
dtgl90vt's Avatar
dtgl90vt
dtgl90vt is offline
I'm assuming your photo is being sarcastic Chevy_Eater?
Old 06-23-2016, 04:44 PM
dtgl90vt's Avatar
dtgl90vt
dtgl90vt is offline
I've been searching my saved threads, and i can't find it. But I think I remember reading that some engine have different sized threads for the oil pressure sender. I don't remember where I read it though. I thought maybe it was in a turbo install thread. Maybe it was a 7.3 vs 6.9 thing.
Devin
Old 06-23-2016, 04:47 PM
Chevy_Eater
Yes, sometimes suggesting using that port starts an argument that you get an inaccurate reading there because you loose a fraction of a degree in heat.
For those that OCD over this I suggest moving the over-temp switch to the rear port and use the front for your gauge. There's plenty of wire to move the switch without modifying anything.
But it really doesn't matter; the coolant travels so fast any difference in reading (if any) is negligible.
You do need a 9/16 8 point to get that plug out.
Old 06-23-2016, 05:25 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Yes, Factory Turbo motors have a 1/4npt hole in the block, N/A has 1/8npt for the oil sender.
But do not use this as a Turbo motor ID, Some like me have tapped it out!
-Enjoy
fh : )_~
Old 06-23-2016, 07:24 PM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
IDK that i would use that port. first, its in the back of the head, second. Trying to run my fan controller from where the idiot light went was a nightmare. One minute it was running too cool, the next it was overheating. Finally bought and IR temp gun, the head port can be as much as 40* off from the t-stat housing (where it should be mounted). Moral of the story is, i drilled and tapped my t-stat housing for my controller, and worked flawlessly.
The oil pressure port, the factory one anyway, is 1/8"npt on NA engines, and 1/4" on turbos. There is also a 1/8" port near the bellhousing on the drivers side that comes off the mains.
Old 06-23-2016, 07:41 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
Odd. I put my own sensor in that place(a RTD sender) and it's perfectly stable and right in the range I expect(185-195F range under normal driving conditions, going higher under heavy load up hills etc).
Old 06-23-2016, 07:46 PM
Chevy_Eater
See what I mean?
Old 06-23-2016, 08:41 PM
fordtrucksforever's Avatar
fordtrucksforever
fordtrucksforever is offline
Man I wish you luck on all that aftermarket stuff. I just finished pulling all of it off my truck and got the stock gauges back working again. I dont need egt, fuel pressure, or oil temp for my work truck. And dont have a turbo.
I guess if you are hot rodding your truck or pulling a big heavy trailer, those will be helpful. I just got tired of all the wires and thermocouples running all over the place. The mechanical oil pressure gauge was run with small plastic line just like whats used on air shocks. I had those melt and get broken. Not anymore!
Quick Reply: Thread sizes, oil pressure & water temp
