Air bag light flashing
Old Jun 24, 2016 | 04:04 PM
sudsmcduff's Avatar
sudsmcduff
Came on other day. No ses light or fault codes. Any ideas what it means? Thanks
Old Jun 24, 2016 | 04:08 PM
Otto396's Avatar
Otto396
Probably means a fault in the safety system. Not sure. Never dealt with those before Is it the one in the gauge cluster or the other one that controls the passenger airbag?
Old Jun 24, 2016 | 04:09 PM
sudsmcduff's Avatar
sudsmcduff
Bottom right gauge cluster
Old Jun 24, 2016 | 04:10 PM
Otto396's Avatar
Otto396
Have you messed with anything in the steering column recently? Maybe a wire was knocked loose.
Old Jun 24, 2016 | 04:13 PM
Pikachu's Avatar
Pikachu
There should be a code stores in the ECS module, if you have a way to read them. ForScan and AE will read that module.
Old Jun 24, 2016 | 04:42 PM
sudsmcduff's Avatar
sudsmcduff
Truck sat for few months and then light came on. Never messed with steering column. I have a scan gauge but nothing on it. My grandfather has one of those expensive snap on code readers. I will get it too him this weekend
Old Jun 24, 2016 | 05:25 PM
sudsmcduff's Avatar
sudsmcduff
Did some searching and found out the flashing is a sequence code. Mine does 4-7. Gonna google and see what I find
Old Jun 24, 2016 | 05:33 PM
sudsmcduff's Avatar
sudsmcduff
Update. Found a multi pin connector unplugged under seat. Thanks for all the help
Old Jun 24, 2016 | 06:19 PM
Rikster-7700's Avatar
Rikster-7700
Lol I think that was the quickest solution to a problem in a long time! Glad you got it fixed and thank you for following up!
Old Jun 24, 2016 | 06:20 PM
Pikachu's Avatar
Pikachu
Check the wiring connector under the passenger seat.
EDIT: Should have refreshed the page before I typed that, lol.
Old Jun 25, 2016 | 08:22 AM
Talltruck's Avatar
Talltruck
Yep suds is correct. The airbag light blinking is trying to give you a 2 digit fault code. It will repeat the code (or codes) over and over so you can count them and when they start repeating you have them all. It will blink the first digit, then a short pause, then blink the second digit. Google the codes up and find your problem. Actually a pretty simple process in comparison to the complexity identifying other faults.
djwill1952
Aerostar
Jul 30, 2012 04:55 AM
kupaa
Jul 5, 2012 08:48 PM
FordF350Baby
1997 - 2003 F150
Sep 28, 2009 05:25 PM
Beamed
Feb 19, 2009 08:40 PM
technomon
Jan 2, 2009 08:11 AM
