air bag buzzer
Old Jan 2, 2009 | 07:12 AM
technomon's Avatar
technomon
air bag buzzer
hi ive got a 94 f150 that i think may have ben wrecked defore i bought it. it has alot of new parts on the right front i dont think the airbag is hooked up when i turn the ignition on a buzzer goes of for about 30 seconds allso the airbag warning light flashes i took the bulb out but cant find the buzzer does anyone know where its located any advise thanks.
Old Jan 2, 2009 | 07:33 AM
pc_2000's Avatar
pc_2000
My guess is the buzzer is probably for the seatbelt. Try clicking the seatbelt when it's buzzing and see if it stops.
The airbag light should come on for a few seconds then go out, to show the bub is good. If it's flashing that means there is a problem with the circuit, either sensors up front or deploying part. That should be checked out as it probably won't work in another accident.
Old Jan 2, 2009 | 08:11 AM
technomon's Avatar
technomon
airbag
its not the seatbelt buzzer it makes a different sound the airbag buzzer is louder and has a different pitch the light wass flashing so i took the bulb out the buzzer only started working when i put a instrument cluster with a tack in it when i took the old one out i found the airbag warning light had ben removed the buzzer may be in the instrment cluster itself but i dident see one thanks
jmuenchow
Jul 9, 2015 08:22 AM
ddeflyer
Feb 10, 2015 01:58 PM
bills86f150
Dec 20, 2014 06:38 PM
Saxon
Nov 5, 2014 07:46 AM
reamer
Jun 4, 2014 11:36 AM
