airbag light
Old Jul 5, 2012 | 04:31 PM
kupaa's Avatar
kupaa
airbag light
My air bag light just came on could i hook up a scanner to see what the problem is or could it be a simple fix.
Old Jul 5, 2012 | 05:18 PM
BlueScab's Avatar
BlueScab
Might be worth checking to see if the passenger side airbag light is working. Most of the time that bulb blows and turns on the light in your cluster.
Old Jul 5, 2012 | 05:59 PM
Horseyfella's Avatar
Horseyfella
My air bag light came on last month, turned out the kid was unhooking the connectors under the seat. It's strange being relieved and angry at the same time.
Old Jul 5, 2012 | 06:41 PM
woodnthings's Avatar
woodnthings
You can try to see if codes for the airbag light. Most of the chain auto parts stores will do this for free. Don't be shocked if it comes up as no codes. Some codes are manufacture specific and are not shown with the generic OBD II readers. Worth a shot though.
Old Jul 5, 2012 | 06:58 PM
VegasFordSD's Avatar
VegasFordSD
You should get the light to flash when your first turn the key to the on position. Count the number of flashes... there will be a slight pause between numbers.
ex. flash flash flash... flash flash = code 32
http://www.airbagsolutions.com/docs/codes/f/a.pdf
good luck with it!
Old Jul 5, 2012 | 08:07 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Yeah mines a 27, been on for years. It's on my work truck though and all I gotta worry about is me most times heh heh.
Old Jul 5, 2012 | 08:48 PM
kupaa's Avatar
kupaa
OK thanks guys,yah it does flash but i haven't counted the flashes I'll count um next time i get in the truck.
MarksA-C
2004 - 2008 F150
Jan 13, 2014 12:23 AM
dfboothe
Dec 18, 2009 08:54 AM
captain p4
1997 - 2003 F150
Jul 27, 2005 04:02 PM
valo
1983 - 2012 Ranger & B-Series
Jan 6, 2005 08:10 PM
dancap
Jul 19, 2003 10:37 PM
